Indiglo Gauges
Old May 1, 2004 | 03:36 PM
Bajanmax's Avatar
Indiglo Gauges
I have a 98 maxima GXE and I installed the indiglo gauges from Paradox-systems today. Instructions very fuzzy. Found some instructions online from MaximaDriver I think. I have 2 questions.
On the back of the gauge panel there are several screws and I got everything installed but the kit has two wires (red & black) that I didn't know where to put them. The instructions said the black one was the ground and the red should be spliced with a blue wire accessing your dimmer switch so when you turn on the clearance light the indiglo would light up. Wasn't sure about the splice so I attached the wire to a battery screw on the back. Gave off a slight buzz but it seemed to work. Do I need to go back and splice since the indiglos are on now but the car is off?
Not all the gauges are working properly. Dials not turning smoothly or at all. How can I get gauges work normally? Does anyone have a remedy for this?
This kit also came with two buttons but one of them seems to do nothing. Of course I may not be able to see this since it's not dark yet. Anyone with the same kit who came help with the troubleshooting? I would really appreciate any assistance the someone can give.
Old May 3, 2004 | 05:38 AM
JPMax's Avatar
What's next!?..
You definitely should splice the red power wire to the blue wire of the dimmer switch. This way the gauges only come on when the car is on.
The needles are sticking because the gauge faces are not lying completely flat against the old ones. Some people use double sided tape. I used some crazy glue around the edges.
good luck.
Old May 3, 2004 | 05:54 AM
Bajanmax's Avatar
The only blue wire I see is one that is blue and has what looks to be a pink stripe. I guess that is the one.
The needles were sticking and I had to put more tape down. Only one was being real stubborn about it. I had to sand it a little. Thanks for the information.
Old May 3, 2004 | 06:30 AM
happyricefob's Avatar
V^___^V
i used a fingernail cutter and trim off the back of the needle so it won't touch the gauge face. i also used some double sided tape as well.
Old May 5, 2004 | 05:08 PM
topp dawg's Avatar
i just buy the indiglo gauges my self but my instruction said to hook it up to the headlight power unit but i don`t know where it is.
Old May 5, 2004 | 06:26 PM
vsamoylov
whats the website where i can get these from?
Old May 5, 2004 | 06:37 PM
sharkulator's Avatar
I just ran the indaglos along with aftermarket fogs through a switch that I placed on the dash. I had the power coming through the ignition so even if I leave them on, they cut off when I turn off the max.
Old May 5, 2004 | 07:29 PM
ohannon7's Avatar
there should be directions either in the "Faq's" section or on VQPOWER.COM "how-to" section
Old May 6, 2004 | 12:26 PM
topp dawg's Avatar
u can try ebay.com
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
