Timing question(not coming from a newbie)
Old May 1, 2004 | 05:39 PM
KsuMax's Avatar
Cheesing away...
In the time I've been on maxima.org, I can't recall ever seeing this question.
Is it possible to advance or retard our timing for some extra power? I know the 200sx se-r guys can, but does our timing chain have anything to do with it? Just wondering since I don't know the answer.
Old May 1, 2004 | 06:17 PM
njmaxseltd's Avatar
It's controlled by the signals from the Cam Position sensors and the ECU. There are no adjustments. A modified ECU is the only thing that can change the timing mapping.
Old May 1, 2004 | 09:53 PM
DAVE Sz's Avatar
Hooooooonda.....
I remeber this question being asked a few times last year. Unfortunatelly we can't adjust our timing.
Old May 1, 2004 | 10:07 PM
Nismo87SE's Avatar
All you have to do is make a timing adjuster simular to the ones for late model ford mustangs. That would allow you to advance or retard the timing.
Old May 1, 2004 | 10:30 PM
MrPink's Avatar
Are we talking cam timing or ignition timing?
Old May 2, 2004 | 04:30 PM
maximus_pr's Avatar
this is lazcano's 7+ sec 300zx using some msd ignition set up being the max engine so similar to the 300zx engine i think this can be done to the max
http://www.urbanracer.com/gallery/ga...eme_rush_5-31-
Old May 2, 2004 | 07:15 PM
DAVE Sz's Avatar
Hooooooonda.....
Did you just say the max engine is similar to the 300zx engine? WTF is wrong with you. I really doubt we share a single thing in common with the VG. Only thing I can think of is the displacement and even there we have 20 or so more cc.
Old May 2, 2004 | 07:49 PM
Chickan's Avatar
actually the VG and VQ are similar, as I've owned both (previous car was a 90 300ZX), but to advance/adjust the timing on a VG you losen the CAS, and rotate it slightly.
On some tt Z's they were able to get 20-30+ HP to the wheels with some simple timing adjusting, though on some cars it was as little as 3-4HP, seemed to vary quite a bit depending on the car.
Hondarydr
Dec 30, 2024 06:15 PM
JMag90
Aug 25, 2015 09:17 AM
mikekay
Aug 10, 2015 12:52 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
