smelly A/C ?
Old May 2, 2004 | 12:38 AM
Max Noob's Avatar
smelly A/C ?
got stanky air comming though my vents. i hear this is caused by mildew getting into your vent system.. what kinda lysol and i spose to use to clean it? also.. if that still doesnt fix it.. what else can make my a/c smell.. i got the condenser replaced but the drier was not. can a bad drier make it smell?
Old May 2, 2004 | 01:12 AM
Prophecy1's Avatar
There is all so a cabin Micro Filter some change for improved air quality. As for Lysol? Pretty sure any scent as long as you make sure it reads Anti Bacterial.
Proph
Old May 2, 2004 | 02:34 AM
maximabebe's Avatar
I would try the Lysol disinfectant trick but my other guess would be your catalytic converter maybe trying to send you a message. It is possible that it may be abandonning you since your car is 9 years old if in fact it is original. BTW, nice color max.
Old May 2, 2004 | 04:08 AM
Frank Fontaine's Avatar
I doubt it's the CAT, it's just the mildew inside the A/C /vent. system. I've done the Lysol trick before and it worked fine.
Old May 2, 2004 | 10:32 AM
_ck69_'s Avatar
I totally agree!
Old May 2, 2004 | 10:47 AM
Terran's Avatar
You've probably already found this, but here are the complete instructions from the faq. http://forums.maxima.org/showthread.php?t=72447 post 29.
Old May 3, 2004 | 09:37 AM
Brudaddy's Avatar
try the lysol and see what happens.
I know that Japenese air condition just sometimes has kind of a weird smell. My old Mazda did, and my friend's Scubby does too.
I think they put rice in there since then just love it so much.
Old May 3, 2004 | 03:46 PM
catalinoiu's Avatar
I cleaned my AC yesterday with Lysol and I could "smell" the difference. I also found that water drain was somehow blocked because I did not have any water under the car after using the AC.
So, check the drain and Lysol should do it.
Old May 3, 2004 | 05:01 PM
Max Noob's Avatar
did the lysol.. smell is about 90% gone..empited a whle can.. dont get that stuff on your paint.. it eat away at like nothing. i needed to use some touchup paint afwards.. thats what i get for being lazy. im probably gonna buy another can to use a little bit after every other car wash. i notice alot of water gets into those vents when u wash your car... thanks guys..
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
