Springs That Will Not 'SAG' for 5spd Max
I have read the FAQ page and read many threads about spring & shock set up's. I have read where some springs tend to SAG on 5spd 4th gen Maximas. Which springs are known to sag? I already have KYB GR2's......which springs should I stay away from and which springs will not sag?
I want a mild drop.. less than 2"...prob in the 1.6" range.
Thanks to all who reply!!
First, Progress springs don't drop that much. They have like a 1.6 or 1.7" drop front with a 1.5" in the back.
They are good from what I have heard.
Also, the ones that I hear are the best for a slight drop and sit even on the 4th gen 5spd are the Tein H-Techs. They drop like 1.5" front and 1.3"rear. I would try those out. There is a group deal in the gd forums for them right now I believe.
Of course, you could always go with the H&R's. They are very small drop too, but are very high quality springs. They have softer rate, so if you have bad roads, you might want to consider the H&R's. They will give a very comfortable ride.
The H&Rs are great springs, but I've seen pictures of them sagging on 5spds. I have the Tokico package with Illuminas on my 5spd GXE. I got a drop in the 1.6-1.7" range. Rear dropped a bit more than the front, but my ride height is now dead even. I love them for ride, performance and look.
Progress do NOT drop down to 2 inches noob! (jk). Sprints are known to drop that low, but some say the ride is harsh. I have progresses w/18's and i can barely fit my fist in the wheelwell (check the homepage). But best of all my springs do not sag.
H&R's are the most comfortable and almos OEM, but then again, they look as high as OEM. Drop is a mere 1.2.
Check this out and use it RELIGIOUSLY!
http://maxmods.dyndns.org/
Brudaddy, have you decided your suspension setup yet?
Thanks for the replies. By the way....I have read and re-read the **http://maxmods.dyndns.org/** information on shock and spring set-up's but there is not any information regarding SAGGING spring problems for 5 speeders.
Thanks Again for the replies. I will have to sleep on my options before purchasing. As well, I will be sure to post my results after several miles so others like myself with a 5spd Max can view...
imported_Nismo_max
02-17-2016 03:39 AM
zzznightmarezz
09-21-2015 06:32 PM
