Did you have to replace the O2 sensor after installing y-pipe?
Old 05-10-2004, 08:48 AM
Pizda Boy
MaxedOutOfCash's Avatar
I'm not sure why it would be bad now, but I get a cel with the O2 sensor... Possible to break them???
MaxedOutOfCash is offline
Old 05-10-2004, 10:10 AM
Str8ridin's Avatar
It's possible it's just a coincidence that when you installed the y-pipe, the 02 sensor gave up.....they usually give around 80-120K miles. Or, they could have not have screwed it in properly, attached the wires properly or got them dirty. Inspect the sensor plug before you get a new one just in case.
Str8ridin is offline
Old 05-10-2004, 01:02 PM
Eric425's Avatar
They break very easily. Reportedly, the Nissan service manual says if you drop one from 8 inches, it's going to need to be replaced. I broke both of mine installing the pipe... $180 for 2 new ones.
Eric425 is offline
Old 05-10-2004, 02:20 PM
THT
Throbbing member
THT's Avatar
Clean them first. I had a CEL after redoing my entire exhaust and my left and right bank O2s were "bad". I removed them and found anti-seize had coated the sensorheads. I used an old sock and some rubbing alcohol to clean them off, reset my ECU and all was good. Be careful of what you use to clean them though as a lot of compounds will kill the sensor.
~THT
THT is offline
Old 05-12-2004, 07:14 PM
99maximagxe's Avatar
I just got a cel today but didnt check out the codes. The first day of installation there was no cel but then today after reving it all day i went to get gas it just lit up. Any possiblitities wat else could it be other than an o2 sensor.
99maximagxe is offline
Old 05-13-2004, 04:33 AM
Str8ridin's Avatar
It could be a hundred things...pull the codes if you wanna know!
Old 05-13-2004, 07:58 AM
Brudaddy's Avatar
None of my sensors went bad when I put on my y-pipe. I do think it is possible that you could have broken one of them or just not put it back in there correctly. I didn't know all that much about those, but my older brother told me how to handle them and they were fine. Props to him.
Brudaddy is offline
Old 05-13-2004, 08:15 AM
VQ30DET
Zero-K's Avatar
my sensors were jammed in the old y-pipe so I assumed I bumped them pretty good taking them out. So when I started the car and had a CEL I wasn't suprised. I pulled the codes and it was for both sensors. I got two new ones for around $180 as Eric425 said. and after putting them in and resetting my ECU my CEL went away.
Zero-K is offline
Old 05-13-2004, 09:04 AM
Pizda Boy
did you guys see a difference in power after replacing them? I don't even know if O2 sensors can cause power loss....
Old 05-13-2004, 11:29 AM
THT
Throbbing member
THT's Avatar
Yes, the front two will cause a power loss if malfunctioning. The one in the cat won't affect power though.
~THT
THT is offline
mrc00l88
01-25-2024 01:14 PM
stromm
08-27-2015 04:13 PM
maxinout93
08-20-2015 02:17 AM
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
Quick Reply: Did you have to replace the O2 sensor after installing y-pipe?
