Help My Clutch Fluid is Leaking!
Old May 11, 2004 | 12:14 AM
MaximaNewb's Avatar
For the past month my clutch fluid went out twice. My pedal would get really soft and I' d check the fluid and it would be below the minimum line. Anyone had this problem before? I couldnt see any leaks but is there any places that i should be checking? Any help is appreciated thanks.
Old May 11, 2004 | 02:10 AM
Nismo's Avatar
you dont see any wet marks anywhere? check all the fittings and see if any of them look oily.
a while back I had about a half inch of fluid lost from the master cyl resovoir and found out that the fitting that connected the line to the master cyl was oily(small leak) so I snugged up the fitting and filled the resovoir and its fine now.
Old May 11, 2004 | 02:41 AM
sryth's Avatar
Yeah...check both cylinders and all lines/hoses. If you have a smallish digital camera w/decent macro, take pictures of all of this stuff; it really helps.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 12, 2015 07:06 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
pears
Sep 18, 2015 05:25 AM
