ppl with 95/96 cai....need advice
Old Mar 25, 2001 | 10:25 AM
buss95max's Avatar
aight im stuck.
the smaller pipe that connects to the throttle body has three holes on the side. the hole in the middle is bigger than the ones next to it. wtf with these holes? what goes in them? im lost. also can i just hook up the K&N to the smaller pipe? and put the maf and longer pipe later on?
Old Mar 25, 2001 | 03:39 PM
buss95max's Avatar
up
blah
Old Mar 25, 2001 | 04:01 PM
Synki's Avatar
Originally posted by buss95max
aight im stuck.
Im guessint they are vaccum lines. But i'm sure you prolly figured that out.
Ask Daniel B Martin, he is very knowledgeable. I'm sure he could tell ya.
Old Mar 25, 2001 | 04:49 PM
nismo96max
you put the airflow sensor in there, the two smaller holes are for the screws, when you take the stock unit out, you'll see a sensor attached to the box
Old Mar 25, 2001 | 05:42 PM
Confused's Avatar
Permanent Maxima.org Resident
the instructions should tell you to take
off the sensor and remove the gold plate... use some silicon to adhere the plate inside the pipe... make sure the sensor fits first.... my holes had to be widened.... then use lock tite (red) on the screws to secure the sensor in there... last thing you want is that plate shooting up into the throttle body.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
