Prob after resetting ECU help!!
Old May 15, 2004 | 07:01 PM
Max-2-GTR's Avatar
I test the ecu today to see if my ks was bad and I got 0505 which means no prob recorded. After I reset the ECU and it starts so badly and the car isn't even moving when I put on drive. The car is also shaking like hell, and everytime I step on the gas, there's smoke coming out of the muffler, not white smoke but I think it's not normal. I need quick help please and the garage aren't open tomorrow.
Old May 15, 2004 | 07:07 PM
nismos14's Avatar
§è~® f®ÈÄk
make sure the screw is turned back all the way on the ecu.
Old May 15, 2004 | 07:52 PM
Prophecy1's Avatar
If you dont set your SCREW to the right position then it will idel incorrectly.
Just becareful and dont bypass the screws.
Proph
Old May 16, 2004 | 08:12 PM
Max-2-GTR's Avatar
thx for the replies. I checked my ecu and found out that I left the screw turn clockwise so I turned it back all the way counterclockwise and the car if fine now. I feel so stupid...but well. Can this be bad for the car for starting it with the ECU screw in the wrong position?
Old May 16, 2004 | 11:49 PM
Prophecy1's Avatar
Your fine dont worry.
As long as you dont break those stops in the ECU you should be fine.
Good luck
Proph
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
