low rpms in neutral
Old May 15, 2004 | 11:06 PM
burgundyblues66's Avatar
low rpms in neutral
just recently, 1996 max manual tranny started to idle at really low rpms. this worries me because at times, it seems as though the car is going to die on me. they sometimes drop to as little as 400 and usually stay around 500 rpm, it seems way too low to me.
any suggestions??????
Old May 15, 2004 | 11:54 PM
KsuMax's Avatar
Cheesing away...
you can adjust your idle, I can't remember how, look in faq's or something.
Old May 16, 2004 | 04:16 AM
maximomo's Avatar
Clean your throttle body. Also check for vacuum leaks.
Adjusting your idle is a bad idea. It didn't adjust itself lower.... either your intake is carbon and oil fouled or you have some other minor issue.
Old May 16, 2004 | 08:02 AM
i havent changed my oil in about 3010 miles. could that be the reason??
also, how would i go about cleaning the throttle body?
Old May 16, 2004 | 08:05 AM
mansurxk's Avatar
read the faq's, it covers all maintenance issues, you hav eto remove the entire intake box and clean it with a toothbrush and some intake cleaner, also clean your IAC valve, and try some seafoam for the carbon deposits, again...read the faqs, doubt the oil would cause low idle
Old May 17, 2004 | 12:29 PM
Brudaddy's Avatar
that is not that bad. Maybe a little low, but manuals are supposed to idle at like 600-650 rpm.
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
