Brake replacement question
Old May 17, 2004 | 08:15 AM
tsi87's Avatar
Over the weekend I changed the front pads, rotors, and calipers on my 99 Maxima. The brakes are much smoother now but I have to press further down on the brake pedal to engage the brakes. I have bled the front brake lines three times to make sure that any air was gone. I am not getting any more bubbles but the pedal still goes down further than I think it should.
Any ideas? Is there a brake pedal adjustment?
Thanks in advance for your ideas.
Old May 17, 2004 | 08:21 AM
Matt93SE's Avatar
STFU n00b!
try bleeding the rears as well.
you have ABS? did you bleed it properly, following the directions in the service manual?
Old May 17, 2004 | 08:28 AM
tsi87's Avatar
I haven't bled the rears yet. I was going to try that tonight. I initially didn't think they would need to be done since I didn't do anything to them.
I need to pick up a manual. I have seen different suggestions on the proper order to bleed the brakes. Most say to start with the ones furthest from the master cylinder.
Old May 17, 2004 | 08:31 AM
Jay93SE's Avatar
Disconnect the ABS harness at the actuater. Then bleed from: LR,RF,RR,RF. You should be good to go!
Old May 17, 2004 | 08:40 AM
max7's Avatar
Why should you bleed the brakes if replacing rotors and pads? If the brake job has been done correctly you shouldn't have to do that.
Old May 17, 2004 | 09:13 AM
Pearl99GXE's Avatar
He changed calipers also.
Old May 17, 2004 | 09:32 AM
max7's Avatar
Sorry it's Monday and I'm still half way asleep.
Old May 17, 2004 | 09:34 AM
tsi87's Avatar
Without the car in front of me and without a manual is the ABS harness easy to identify and why do you need to unplug this in order to bleed the brakes?
vingodine
45
May 21, 2016 12:46 PM
JMag90
Aug 25, 2015 09:17 AM
egali045
Aug 16, 2015 01:19 PM
Samedi
Aug 13, 2015 04:05 PM
