Maxima stalls when starts early in am
Old May 17, 2004 | 10:20 AM
Show Maxima's Avatar
When my brother starts his car in the am, he has to rev the engine up almost consistently for about a minute or so, in order to keep the car from stalling. does anyone know what this might be, or why this might be happening, what to replace/repair to resolve problem.
regards,
Brian
Old May 17, 2004 | 10:34 AM
Ramius83
I also had this same problem just last week. I relocated the MAF a while ago for the turbo kit. I found out that the new connections I made to move the MAF farther away were loose. Once they were re-done, everything worked perfect.
I had the following symptoms:
1) Car would start and rev to 500 RPMs, but immediately cut off.
2) To get the engine started/going, I had to hold the gas pedal down and start the engine at the same time. I then had to ride the clutch to make sure the car would not die on me.
3) When sitting at an intersection, the car would just randomly die on me....
Old May 17, 2004 | 10:51 AM
ahh i c, and i just sold my maf sensor today. lol, well too bad for my brother, gotta go buy one now... any other suggestions as to what this may be?
Old May 17, 2004 | 11:48 AM
Chickan's Avatar
check the connection to the MAF before just replacing it, could just be corroded contacts. Also, I've heard of coolant temperature sensors causing similar symptoms, so you might want to replace that if it is still the original one.
Old May 17, 2004 | 12:02 PM
Cal0205's Avatar
Can it be the fuel filter that's all clog up? Changed mine a month ago and never had the problem.
btw my old fuel filter was dirty!
Old May 18, 2004 | 06:27 AM
I dont know, thats a great idea, I will look into those options and see what we can work out.
Finkle
Sep 27, 2015 09:53 PM
mls277
Aug 11, 2015 07:18 PM
dauntlessmax
Aug 5, 2015 10:29 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
Jcof88
Aug 3, 2015 10:43 PM
