idle air control valve cleaning - cleaning Q.
Old May 17, 2004 | 12:52 PM
njmodi's Avatar
Do I get a tax break?
While cleaning the throttle body this weekend, I decided to remove the idle air control valve (IACV) and clean that too... I tried to follow the instructions posted in the FAQ, but I'm not sure I understood them correctly... here is what I did.
I removed all the connectors and 3 bolts (12mm) that hold the entire IAC assembly onto the throttle body.
Ok now how what? All I see there is a round cap covering some type of hole? (on the side that was toward the throttle body. I clean all this off - so the round cap is all shiny (sorta gold/bronze colored - like a new bolt)... and I tried to clean up everything under the cap.
On the side where the connectors are, there were two phillips screws that let another piece of the IAC assembly come apart - (with an o-ring sealing that seam)... so I clean out that piece and the plastic dome-like thing (techinical huh?) ...so I cleaned that up... now on this smaller piece, there were yet another two philips screws that presumably hold the actual IAC valve in place.. is this what I should have opened and cleaned? I didn't do that because the Haynes manual said the part is electrical and shouldn't be messed around with...
I don't see how cleaning what I did is going to help anything - which part of all that moves to control the idle and what exactly should I have opened up and cleaned?
Its driving me nuts and the Haynes manual is useless on this subject...what "should" I have done..?
Any help?
Nirav
Old May 17, 2004 | 01:08 PM
Kevlo911's Avatar
Kevlo for President
You did it right. Spray some down hte tube and scrub it out with a brush or rag.
Old May 17, 2004 | 01:20 PM
njmodi's Avatar
By tube, do you mean the tube that leads into the throttle body? I did spray a bunch of TB cleaner into there and tried to clean it up as much as I could.
Old May 17, 2004 | 01:25 PM
Kevlo911's Avatar
Kevlo for President
the copper tube that a hose connects. The hose is connected to the midpipe.
Filter - MAF - MidPipe - TB - Intake Manifold - IACV connected to intake manifold.
Old May 17, 2004 | 01:32 PM
njmodi's Avatar
Even though I have no idea what you are talking about (at engine components at that level), I'll take a look under the hood when I get home and see if I can figure it out... I'll post back with my success/failure in an hour or two..
thanks,
Nirav
Old May 17, 2004 | 01:41 PM
Kevlo911's Avatar
Kevlo for President
That is order of hte intake on our engine to let you know what is what
Old May 17, 2004 | 01:49 PM
njmodi's Avatar
I got it - so you are suggesting that I clean out the hose/tube that connects between the intake manifold and the IACV... just to be sure I am finally on the same page - this is the only tube I had to disconnect from the IACV before pulling it from the car... right?.. fortunately I can clean that tube easily..
Old May 17, 2004 | 01:53 PM
Kevlo911's Avatar
Kevlo for President
Well you don't need to clean the tube itslef. But the copper tube hte rubber hose connects to on hte IACV
Old May 17, 2004 | 01:56 PM
njmodi's Avatar
got it... thanks for all the help...
lux97Max
19
Aug 27, 2015 07:48 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
bassmann
Aug 13, 2015 10:13 PM
