Ignition Switch Problem
Old May 19, 2004 | 06:05 AM
dkbrown's Avatar
Strange problem, harder to explain. Sometimes when I turn the key on the ignition, I get lights, but does not turn over the engine. Usually if I go back and forth it will eventually engage. It has always eventually started with myself, buy my wife has not had such luck, or wrist strength.
Any thoughts out there? I am baffled, and not ready to give a mechanic an open ticket to find a problem.
Thanks to all.
Old May 19, 2004 | 06:36 AM
Mad-MAX_SE's Avatar
Still kickin'
i have the same problem, and from what i've been told it's the electrical relay that's causing the problem. the part is like $28. it's located under the shroud on the steering column...i'll let the other guys explain it, since i haven't done it yet.
Old May 20, 2004 | 10:34 AM
dkbrown's Avatar
Found Answer
The solution is in the 4th Gen How to section. Should have looked there first, but thought it was too obscure. Guess it is more common than I thought.
Thanks to all.
Old May 20, 2004 | 11:15 AM
_ck69_'s Avatar
Thanks to all.
Sorry, but I must be blind. I can't seem to find it in the How-To section. Can you point me in the right direction? Thanks.
Old May 20, 2004 | 11:22 AM
njmodi's Avatar
Do I get a tax break?
FYI - http://forums.maxima.org/showthread.php?threadid=200696
Old May 20, 2004 | 12:13 PM
_ck69_'s Avatar
Thanks!
Old May 20, 2004 | 12:19 PM
_ck69_'s Avatar
Thanks to all.
I'm having the same problem in my car where it sometimes won't start, not even turn over. All I can hear is a clicking noise from the engine. Are you getting that clicking noise as well?
Old May 20, 2004 | 12:21 PM
njmodi's Avatar
_ck69_ - your problem sounds like either the starter relay or the starter itself...
nismology's Avatar
Have you checked the battery terminals for corrosion? Also how old it your battery?
Old May 20, 2004 | 07:29 PM
_ck69_'s Avatar
I just had the battery and the starter replaced.
Old May 20, 2004 | 08:27 PM
MaximamixaM's Avatar
does the check engine light always come on when inserting the key and cranking?
Old May 21, 2004 | 06:03 AM
dkbrown's Avatar
No clicking. Just light on the dash. I thought up to now that it was a badly made key.
mikeg75
Nov 30, 2015 05:12 PM
rnb754
Sep 14, 2015 11:39 PM
Maxie40
Sep 14, 2015 11:28 AM
