Help With Middle eastern variable intake manifold
Old May 19, 2004 | 12:01 PM
mighteatyou's Avatar
I have this Intake manifold here and i have a few questions
if i bring it to a reasonable mechanic can he install it for me with any problems? it says that the kit may need a few extra parts. I also read that An RPM switch will be needed to control the switch that changes intake runners. Is this true? and where can i get one? Would a mechanic have one on hand?
I am planning to install the stillen supercharger into my car shortly. I called stillen and they said that this manifold will not interfere with the supercharger. I also hear that the Jim wolf ECU works best with the manifold. BUT can i get the Jim Wolf ECU and still get the stillen supercharger???
i need help and i have alot of questions i dont know. PLEASE EXPERTS HELP ME OUT.
Old May 19, 2004 | 12:10 PM
Flava_24/7's Avatar
Boosted Panda
Looks like you should have done some research bfeore getting the MEVI.
I am not an expert, but I can answer some of the basics.
Yes, you will need an RPM switch plus some other small parts. Read the FAQS.
Yes, you will need the JWT ecu to take advantage of the MEVI since the JWT ecu has the raised rev limiter.
If you are going to SC, the ecu will have to be programmed for SC applications. You can use both MEVI and SC.
Old May 19, 2004 | 12:59 PM
Conrad283's Avatar
I need a truck
Get it done by Jeff at MaximumTuning, he's in Glen Clove. Should be $150 install. Better that way instead of messing it up
Old May 19, 2004 | 02:37 PM
bump
fgdfgdfgdfgdfgdf
Old May 19, 2004 | 02:43 PM
mitch33x's Avatar
http://forums.maxima.org/showthread.php?t=217001
Old May 19, 2004 | 03:20 PM
Conrad283's Avatar
I need a truck
Originally Posted by mighteatyou
fgdfgdfgdfgdfgdf
Did you have a seizure while typing your response?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
JonBlz
Oct 5, 2015 06:02 PM
MichMaxFan
Sep 30, 2015 09:18 AM
