Catalytic Convertor
Old May 19, 2004 | 05:00 PM
CUSEMAX's Avatar
Catalytic Convertor
My check engine light came on and autozone said that it was a catalytic convertor problem. I looked and no one sells a new catalytic convertor except nissan dealers. I looked at the jerry-rome site and they were 800 bucks. I looked on ebay and they have the (illegal?) high flow pipes for only 30 dollars.
Any advice on what I should do????
Old May 19, 2004 | 05:08 PM
Terran's Avatar
You won't pass emmissions with a straight pipe (I would guess NY has emmissions right?).
Old May 19, 2004 | 06:19 PM
VQuick's Avatar
Chassis Freak
Salvage yard! If you don't know of any local ones, try car-parts.com.
Old May 19, 2004 | 06:52 PM
njmodi's Avatar
Do I get a tax break?
You can get cheap (in price and quality) catalytic converters from Midas etc... depends how much you care about the part quality.
Old May 19, 2004 | 07:33 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
no emmisons in NY
Old May 19, 2004 | 07:34 PM
DAVE Sz's Avatar
Hooooooonda.....
Most aftermarket cat converters are bad quality. The OEM cat costs around $800 but the honey comb "filter" element in there is superior to those sold in the aftermarket cats. If it was a cat problem maybe the O2 sensor is the culprit. If the cat is bad, it's most likely due to your car running rich and making the cat go bad. Get a new one and most likely it will go bad too and a lot faster than the stock one. Maybe 2 weeks time?
Old May 19, 2004 | 07:49 PM
hasei's Avatar
日産
How about this:
http://www.catalyticonverters.com/ni...converter.html
I never actually bought one from them though I was thinking about it.
Old May 19, 2004 | 09:25 PM
Prophecy1's Avatar
Someone else sells them you just have to find it. The link above works, also check out a good junkyard.
Proph
Old May 20, 2004 | 07:25 AM
20V6's Avatar
I don't think a malfunctioning cat would trigger the Chk.Eng. light because that's strictly a mechanical device. The O2 sensors are electronic and could trigger the light, but I thought they're sitting prior to the cat, so they "wouldn't know" if anything was wrong with the cat....
In any case there is something wrong with fuel supply/ignition/emission systems that triggered the light...
Old May 20, 2004 | 08:31 AM
THT's Avatar
THT
Throbbing member
Don't 99s have four sensors; one in each part of the Y, one precat and one postcat? Read your ECU codes.
~THT
Maxima_Joe
Nov 25, 2015 08:19 AM
09maxshawn11
Sep 30, 2015 10:28 AM
DayHeyZeus
Sep 11, 2015 03:17 PM
carid
Sep 9, 2015 05:06 AM
Justin Kroll
Sep 2, 2015 11:06 AM
