Driver side CV install
Old May 21, 2004 | 03:48 PM
MAXIN's Avatar
Anyone have good tips on getting the driver side cv shaft all the way in? (locking that circularclip in place). I thought I had it all the way in since the weekend, till 2 days ago when all the oil started streaming(like a slow faucet) out the bottom of the inner joint. (had tranny out for a diff bearings job)
And it looked as if the shaft moved outward a bit, so I know it wasnt fully inserted. How do you guys get that circular clip to lock in place?
If I push/jam on the axle any harder the car will fall off the jackstands.
Passenger side seems fully inserted.
Old May 21, 2004 | 06:18 PM
95MAXIMASExy's Avatar
1)when i replaced my drivers side boot i reincerted the axel with a spot of grease on the circular clip to keep it centered (for easy insertion).
2)it shouldnt be that difficult to insert it.
3)if your car is about to fall off the jackstands no matter what you are doing to it--- it is NOT properly (safely) jacked up! please prop it up in a fail safe manner, at least put your tire/rim under the car so if it does fall it will not crush you, we do not want you to be hurt.
Old May 21, 2004 | 10:27 PM
Lonely Driver's Avatar
If the c clip won't lock into place, open in up a little bit more. Don't open it too wide or the next time you try to remove the axle, the clip may break.
fastcarny
May 18, 2020 10:40 AM
boomerbrian
Nov 8, 2015 05:10 PM
rtirbany
Sep 8, 2015 11:46 AM
shaunkey1
Aug 18, 2015 10:09 PM
