haedlights
Old May 21, 2004 | 11:40 PM
KitsapMaxima's Avatar
headlights
I have been using some aftermarket bulbs they where 80/100 watts and my wiring just burnt up and now i i get no power to the haedlights checked the fuse and the relay under the hood i dont know where to check now i have to wire them right to the battery is there another relay some where that might have went out?
Old May 22, 2004 | 12:06 AM
BadKarma99-4spd's Avatar
im not sure what wattage our headlights use, but if you used too high of a wattage you could have cooked your wireing and/or harness(aka the thing the bulbs plug into).
check the condition of this area, they run like 22 each i think from the stealership
Old May 22, 2004 | 12:14 AM
Yeah i burned those up and they shorted out and now i cant get any power to the headlights I had to use some wire clips on the bulbs the plugs are burnt up. I was just wondering if theres another relay or something that burned up?
Old May 22, 2004 | 07:38 PM
i doubt you cooked a relay, you can go to the store, walmart, autozone and buy a circuit tester or something like that and you can tell if your plugs are getting power
im terrible with electric stuff but this is what happened to mine, and i just spliced in the new wires for the plugs
Old May 22, 2004 | 08:31 PM
Taken2DaMax's Avatar
You will have to replace both the bulbs and harness. If you want to continue to use those bulb (which you should not), you will have to upgrade the harness to a bigger gauge.
Our headlight harnesses suck at holding higher wattage bulbs. The lowest watt. that i used and still burnt out on me was 65/55. We must use 55 watts or nothing at all.
maximaman10
Mar 10, 2006 08:05 AM
