1999 SE Starting Problem
Yesterday, my wife and I were out running some errands. As usual, the car performed without any noticable problems. On our way home I filled up with gas. I pulled into the garage like normal and parked the car.
Later in the day I needed to run back out and went to start my Maximia. The car refused to start. The starter was cranking the engine, but no attempt to fire up the engine. It seemed as if the car had no plugs in it. The typical lights came on the dash, but all the engined did was crank without firing. The battery is like new - so that's not the problem.
Does this sound like a fuel pump problem? Electrical? Are there any specific things I can check or look for? Fuses? Gas problem? What is the likely scenario here. Happened to anyone else? Any other ideas before I have it towed to the dealer? Plelase advise.
The car has 41k miles on it.
Thanks,
Rick
Thanks,
Rick
It sounds like your having the same problem as many of us. Check out this thread .
http://forums.maxima.org/showthread.php?t=306697
From the way it sounds, this may be problem even a dealer can't fix? Has anyone had the dealer fix this problem?
Thanks again for the reply,
redjr...
Originally Posted by redowns
Thanks. I read the thread, and while there sounds like some similarities I'm not so sure everyone has the same problem. Mine acts as if nothing is firing thus not turning over. It's not a matter of cold temps, or jiggling the key. I check all my fuses and still no go. It's not even attempting to fire up! It's not intermittent either - just plan won't fire.
redjr...
redjr...
http://www.motorvate.ca/mvp.php/516
this was the site on how to fix the stickyness. i dont know if this is your exact problem, and it looks a little complicated. but this could be a suggestion. Good luck.
With the car being a 99, sounds like your immoblizer been triggered. Common problem with the 99. Only a dealer can reset and reprogram keys. Cost 100-125.
Thanks,
Rick
Thanks,
Rick
Anyway, I'll try a few more attempts tomorrow, but I leave town on business tomorrow evening. I'll have my wife call a local shop and get it towed for them to take a look see - at least at the obvious!
BTW, is there anything that could go wrong (or right) with the ECU where it would prohibit the engine from starting? Some set of circumstances that the ECU is interrupting as 'don't start the car'?
Another thing that's odd, is I had the car serviced about a month ago at the local NIssan dealer - nothing related to this problem. AT least I don't think so. But, I've always been skeptical of dealers - wanting to believe that while fixing one thing they often intentionally sabotage another area, just to get a few more hundred dollars somewhere down the road. I don't want to believe that, but I wouldn't put it past them. I know I sound paranoid, but I simply don't trust dealers at all.
Thanks again,
redjr...
Thanks for the tip. If the immoblizer is to blame, does the car need to get towed to a dealer, or can just the keys be taken in? I wasn't even aware of this system on my car. I have rather normal looking keys, with no obvious electronics - then maybe that's the point. Does the key look like a normal key? Can't imagine having to incurr the cost of towing just to have the system/keys RESET! Wait, yes I can. More money for the dealer.
Thanks,
redjr..
Yes, must tow car to dealer, have to reprogram system in car and all keys.
i went through this no-start condition about 1 1/2 years ago. Dealer has no explanation as to why it happens.
Is there a valid reason I can't search this and other forums? I try, but keep getting as message to the affect I don't have proper access. I'm a registered member. What gives?
redjr...
redjr...
The search function is not "turned on"....I think because of bandwidth issues on the server.
Another thought, if the dealer says its your ECU, take your car to another dealer. There was a thread here recently when someone had the same problem as you, dealer said car needed new ECU, (big dollars) when actuallly it was the immoblizer. Believe Nissan issued a TSB on this problem. Common to the 99 Maxima's.
BTW, my keys look very normal. No evidence of a micro-chip like the GM cars. Is that correct? Do the keys look vastly different with the NVIS, or are they that stealthy? IOW, how can I be sure it's the immoblizer?
Thanks,
redjr..
All 99's got the security chip keys. added protection.
The easiest way to find out if its the key is turn the ignition to ON and check to see if the security light switches off. If it doesn't then the key is bad. If the light turns off then i'd say you will need to extend yourself to some unknown expensive dealership help.
Anyway, it will be towed to the dealership today. What choice do I have? I'll be out of town on business the rest of the week, but my wife will be relaying messages as to what they find. I don't even want to think about the cost! I loved my 89 Maxima. I never had any of these problems. Now I just wish I had it back.
Regards,
redjr...
Here is a question do you have a square key at the top?? or its a roundish oval key?? If its square then you have the key imobolizer system. If you had tried another key after a couple try's with this possible bad one you would be ok. But I think the number is five times witha bad key that the computer changes the code and rejects the current key. So you have to take it to nissan towed of course...and have the good key reprogrammed. Kinda sucks but not much you can do about it.
sctludwig
09-01-2022 01:32 PM
boomerbrian
10-31-2018 10:25 AM
trungg86
09-04-2015 04:58 AM
