code 10-8, evap can purge vol ctrl valve
Old May 23, 2004 | 06:45 AM
slag's Avatar
is there a quick fix for this, or do I just have to buy a new solenoid or valve?
I got this error on my 96 max, in addition to the knock sensor error, 03-04
Tried to search but its limited to donating members. Tried to become a donating member, but received error they are too busy to add donating members. Since my hands are already tied, can somebody come tie my feet as well?
Old May 23, 2004 | 09:37 AM
Kevlo911's Avatar
Kevlo for President
1008
The Evaporative Emission (EVAP) Canister Purge Volume Control Solenoid Valve uses an on/off duty cycle to control the flow of fuel vapor from the EVAP canister. Diagnostic Trouble Code 1008 is set when the Engine Control Module (the computer) detects an improper signal through the valve. The problem is likely to be in the electrical wiring, harness, or the valve itself.
Check fuse #58 (10 amps) and replace if necessary.
The CPVCSV is easy to see and reach. It is located in the engine compartment, mounted to the top of the upper intake manifold. Notice the Vehicle Serial number stamped into the firewall. Put your finger on the third-from-last number. Move your finger three inches toward the radiator. That's the CPVCSV. It has one two-wire electrical connector and two vacuum hoses. It is directly above the ignition coil connector for cylinder #5 and has to be removed in order to replace the #5 coil or spark plug.
You may test the valve. This test procedure is performed with the engine off. Remove the electrical connector and both vacuum hoses. Fasten a length of clean rubber vacuum tubing to either nipple. Gently blow through the hose. The valve should be closed and it should be difficult or impossible to send air through the valve. Now use a pair of fused test leads to provide 12 volts to the electric terminals. The polarity doesn't matter. With the solenoid energized the valve should be open and it should be easy to send air through the valve.
http://forums.maxima.org/showthread.php?t=265311
Old May 24, 2004 | 06:10 AM
S103100F's Avatar
i have sam problem for past month
where is fuse #58 ?
maxinout93
Oct 31, 2015 02:04 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
