HELP! Power Steering Belt - HOW DO YOU REMOVE IT? (CAR IS UP ON JACKSTANDS)
Old May 24, 2004 | 02:29 PM
KWheelzSB's Avatar
Please help me. My car is lofted as I type here. A quick response would be greatly appreciated.
I tried loosening what looks like the tension adjuster bolt (vertical bolt with a set screw/bolt) in back of the power steering pump pulley, but no tension was released on the belt.
Should be simple, right? What's the trick here?
Hayne's doesn't cover this procedure.
Thanks in advance,
-K-
Old May 24, 2004 | 03:00 PM
Broaner's Avatar
2060lbs and falling...
It was rather difficult for me. Make sure your going the correct direction on the bolt. You also need to loosen the bolt above the unit. I'm not sure what size it is. I want to say 14 or 16mm bolt I'm not sure. The bolt you need to loosen is on the inside of the inboard side of the unit car. Anyone else with input? Sorry man. I tried.
Old May 24, 2004 | 03:48 PM
KWheelzSB's Avatar
Thanks for the reply.
Yep, I tried both directions on the vertical bolt after loosening the horizontal bolt (set bolt?) with no luck. I tightened it all back up & will have another shot at it as soon as I get the solution on this. . .
Still on a fact-finding mission if anyone wants to contribute.
TIA,
-K-
Old May 24, 2004 | 03:57 PM
RA030726's Avatar
I'm nutty for Nissans
Here this is out of the FSM http://www.greghome.com/images/Maxim...DriveBelts.jpg
credit to greg.
Old May 25, 2004 | 04:36 AM
KWheelzSB's Avatar
credit to greg.
Maxima10to1, Greg,
Much appreciated!
So, by the look of it, I was failing to loosen the "invisible" mounting bolt on the very back of the pump (not related to the two bolts on the tensioner assembly). Makes sense (duh). ;oP
Hopefully, that will get it done as long as I can reach the bloody thing!
www.maxima.org members save the day, yet again. . .you guys rock!
Old May 25, 2004 | 05:03 AM
Ladzio's Avatar
OMG, how dumb I was. I tried to change belts and did not know of that third bolt on a pulley. I thought it was pretty terribley rusted there and tried to shake it loose with strike of the hammer. Thanks people!
Old May 25, 2004 | 05:48 AM
KWheelzSB's Avatar
"Great" minds think alike - I did the exact same thing. LOL!
Old May 25, 2004 | 10:16 AM
gtr_rider's Avatar
192.168.1.1
This site is great huh? I wouldnt have known there was another bolt either if I didnt come here. Hey K, check out the sig:-D
Lakersallday24
Jun 16, 2019 01:35 AM
02PearlSE
Oct 7, 2015 02:12 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Mrbizness1
Aug 18, 2015 08:43 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
