JWT Pop Charger on an Injen
Old May 24, 2004 | 04:40 PM
LIMaxin
I was wondering if the JWT Pop Charger would be to heavy to put on an injen. I plan on attatching a MAF adapter backwards onto the pop charger and then claming one of those rubber pieces to the adapter as well as the intake pipe. I think that it will probably fall off just wondering if anyone has this setup.
Old May 24, 2004 | 04:44 PM
|Bijan|'s Avatar
UCF Lexus
As long as you secure it right and TIGHT it will stay on.
Old May 24, 2004 | 06:14 PM
LIMaxin
ya im gonna try to mount some sort of bracket to give it extra support but its almost worth it to just get a smaller and lighter filter cuz i doubt the pop charger is going to give much advantage over a regular filter anyway
Old May 24, 2004 | 07:12 PM
happyricefob's Avatar
V^___^V
double/triple hose clamp it if you don't feel safe about it
Old May 24, 2004 | 07:16 PM
Conrad283's Avatar
I need a truck
The injen has a piece that's welded on the second elbow (the one after the MAF) which attaches is bolted to the engine, so I don't think you'll have a problem. And if you are getting an injen, mount the MAF properly, that harness that plugs into it isn't that long and if you have to run it to the other side, the wires are gonna be super tight
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Mahmuth
Sep 25, 2015 10:08 AM
