MEVI installed, running lean? HELP
MEVI is installed, everything works great, engine runs great. However I am now getting the 0115 code, fuel injection system lean (right bank). The sticky indicated it could be 1 of 7 things.
- Intake air leaks
- Defective Front Heated Oxygen Sensor
- Fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow Sensor
Upper manifold is torqued to spec, everything is lined up properly. If i had a leak wouldnt the engine run like crap?
I'm pulling vacuum from the FRP, if that matters
Anyone have a problem like this?
Thanks in advance
- Intake air leaks
- Fuel injectors
- Exhaust gas leaks
- Lack of fuel
Thanks in advance
Running lean is a very bad thing and can cause engine damage prettty fast...Try reseting the code and see if it comes back..
In the mean time check the vaccum pressure with a gauge..I dont know off hand what the gauge is called but any local auto parts store will have it...
-matt
-matt
I reset the ECU and the code went away, and has not come back, phew. I guess it came on because I beat the **** out of the engine right after I got the VI working, weird.
The VI ROCKS, now its time for an ECU. I wish Technosquare would come out with a raised rev version of their ECU already.
maxprivate
11-29-2017 08:52 AM
Finkle
09-27-2015 09:53 PM
MaximaDrvr
08-19-2015 08:20 PM
