Cant get my hub nut to break
Old May 28, 2004 | 12:38 PM
Oblongshapes's Avatar
Im changing my rotor and my hub nut will not budge.... any suggestions. I have a breaker bar with a pipe attached to a 36 mm socket, with PB blaster on it... and nothing
thanks
Old May 28, 2004 | 12:50 PM
MdMaxDrvr's Avatar
thanks
Maybe I'm missing something here. If you are trying to change your rotors (assuming they are disk) all you need to do is take off the caliper and pull the rotor off. Mine was a bit rusted but a few bangs with a small sledge hammer (I rotated the rotor so I hit all around) and it popped off. Hit it from the backside. The hub doesn't come off with the rotor, it slides over it, if you look at your new rotor you'll see.
Old May 28, 2004 | 01:02 PM
RA030726's Avatar
I'm nutty for Nissans
yopu do not need to remove the axle nut. As mentioned above to get the rotor off just remove the caliper, more specificaly the torque member. This is held on by (2) 19mm bolts. Its also a good idea to remove the (2) 17mm bolts that hold the caliper to the torque member first. Also compress the piston in the caliper with a C clamp. The rotor will need some help comming off. Use a mallet an hit the rotor as said above.
Old May 28, 2004 | 01:08 PM
MdMaxDrvr's Avatar
Detail, details just had to one-up me huh? lol J/K Yeah I probably should have been more specific. My rotor took some good hits to come off and they were only on for a yr or so. It may not seem like its doing anything then all of the sudden 'pop!'.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
