Headlights dimming
Old May 28, 2004 | 02:59 PM
XaMMax's Avatar
Headlights dimming
While driving at night I notice that my headlights will often dim just slightly (noticably though) and they also do it when I roll up my windows. Do I need a new battery or is it something more difficult?
Old May 28, 2004 | 03:00 PM
Nismotic's Avatar
Always sunny in philly
this is normal. get an optima battery.
Old May 28, 2004 | 05:47 PM
mendon99's Avatar
tastey wheat
do you have a system? if so, and if you run it all the time, get a capacitor, its exactly what they are made for..decent prices on ebay, brands don't really matter
Old May 28, 2004 | 08:18 PM
JPMax's Avatar
What's next!?..
If you have a high wattage stereo system, you probably need a capacitor.
If not, then go to Autozone and get your alternator and battery checked.
Old May 29, 2004 | 07:13 AM
XaMMax's Avatar
I do no have a stereo system (yet) I have only replaced the front door speakers.
Old May 29, 2004 | 07:23 AM
aspec0002's Avatar
its normal
Old May 29, 2004 | 07:58 AM
Kevlo911's Avatar
Kevlo for President
Unless you get an upgraded alternator, it's normal.
Old Jun 1, 2004 | 06:38 PM
XaMMax's Avatar
Yeh but its annoying they also seem to do it when I brake. Not only that but even my map lights dim when they are on.
Old Jun 1, 2004 | 07:10 PM
VIP Maxima
this is normal. ur puttin more pressure on the battery and the cables when u try to roll up windows while the lights are on, this causes less electricty transfered to the lights, thus u see them dimming.
Old Jun 1, 2004 | 07:45 PM
nostrixoxide's Avatar
I know this might seem normal to everyone, especially with a substandard battery but you might want to check your ground wire. Mine used to do the same thing & it turned out that the ground strap on the negitive side of my battery was loose. Maxima's are notorious for having bad grounds, Stillen sells a grounding kit but I find it to very over priced. You can find grounding kits on ebay all day long for cheap, look into it. Heck you might even find a few ponys especially if your ECU is struggling to get good current flow from your battery. Just my 2 pennies........
Old Jun 1, 2004 | 09:12 PM
DAVE Sz's Avatar
Hooooooonda.....
^Yep. It's not normal. It means a ground or two is weak, rusted or something. Try to find some ground points and clean them up. I looked in the FSM but couldn't find them.
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
