air write-up?????
Old May 29, 2004 | 09:49 PM
97BLUEMAX's Avatar
air write-up?????
are there any air conditioning write-up's i looked in all the sticky's and couldn't find any
Old May 29, 2004 | 09:54 PM
Nismo's Avatar
because gernerally its not really DIY job and you have to be certified to even buy refrigerant.
Old May 29, 2004 | 10:10 PM
DAVE Sz's Avatar
Hooooooonda.....
??? WHat? Go to autozone and buy yourself a can of r134(refrigerant) and a hose to hook i up. Connect it to your LOW side of the pipes(green cap with L on it). Turn on the car and put the AC on to max. Connect the hose with can and you're done. It says all that on the can(order might be different).
Old May 29, 2004 | 10:18 PM
Gibby's Avatar
Yes, recharge is easy. Kits are cheap, and can be purchased even at WalMart. However, if you want to change compressor, expansion valve, condensor, etc... you will have a terrible time finding any help for instructioins. Even the Haynes and Chilton manuals say to take it to a proffesional for A/C work. I'm currently having problems with my A/C as well. I tried for quite a while to find troubleshooting/install help, but had no luck. Everyone says "take it mechanic." Sucks, eh???
Old May 29, 2004 | 10:19 PM
Nismo's Avatar
im not talking about those drop in cannisters. So what if theres a leak? you can keep on adding those little cans all day but you still want to detect the leak dont you? how are you going to evac the refrigerant and vacuum it down? Yes you can do a service at home other than topping off lost refrigerant but you still cant buy refrigerant without certification. Those bottles are not actual refrigerant, its r134a compatable mixture that can mix in with refrigerant
Old May 29, 2004 | 10:25 PM
maximus_pr's Avatar
http://www.jcwhitney.com/webapp/wcs/...&storeId=10101
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
