'98 SE hard/weak starting
Old May 30, 2004 | 08:13 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Lately I've been cold-started my car in the mornings and when I turn the key to start the car, the cranking is very weak & slow, almost like the battery is dead, it seems to start but won't turn over, takes about 2 -3 tries to get it running on a cold start, I even have to press the gas pedal down a little to get it going and that usually does the trick. SES light is not on after startup. When the car is warmed up I have no problems w/ starting. Could the battery be going bad or is this a problem w/ the fuel system?
Old May 30, 2004 | 04:46 PM
bump......
Old May 31, 2004 | 07:26 AM
anyone????
Old May 31, 2004 | 09:25 AM
96maxdaddy's Avatar
I would run your car to autozone or someplace that offers free battery load testing, just so your sure the battery is good.
Old May 31, 2004 | 12:25 PM
G20Flyer's Avatar
battery is a piece...get a new one
Old May 31, 2004 | 03:11 PM
98fiveSpeed's Avatar
simple fix. I would start with cleaning out the throttle body and would also clean out the air-filter.
How the clean the throttle body is covered in one of the stickys..
Old May 31, 2004 | 03:43 PM
97blackv1's Avatar
check your starter!same symptoms as i had
I went out and bought another battery and it ended up being the starter.
Good luck
Old May 31, 2004 | 04:05 PM
95snakekiller's Avatar
grease the starter
Old May 31, 2004 | 07:53 PM
thanks guys ... i'll have the whole electrical system (starter and all) checked out when I get a chance ... hopefully the car won't die out on me until then .. i'll keep everyone posted on what's really causing my car to have bad cold starting all of a sudden
good to know my '98 isn't the only one having starting issues
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
