Weird noise when AC is on
This noise has been occuring for about a year now. Whenever I turn the AC on. I hear a loud noise that has some creaking or squeeks to it along with the fan. It seems to be coming from the belt area around the pulleys. I first thought it was the compressor but wasn't to sure. It makes the car sound old. I feel embarassed when I turn on the AC while sitting in traffic because the sound is annoying and is noticeably audible and gets louder at the onset on acceleration, once I accelerate the noise is gone. This noise is also virtually nonexistant when the fan is on or the AC is off. ON the same note, I was riding in my freinds '93 Camry last night and noticed he had the same noise when his AC was on but the noise disappeared when the AC was off. Has anyone else had this problem before? What is it and how can it be fixed?
I had the same problem it was the clutch (yes clutch) in the AC compressor.
Try the belt first though it will save you a ton of time and money if that is it.
Originally Posted by wunfstmax
my compressor makes the noise regardless if the ac is on or not...you could try gettin a shorter belt and if the noise it gone then that would be your problem
I'm already usig shorter belts. I still have the RVM underdrive pulley. I haven't had any problems with oil leaking. I remember that I had to have shorter belts than stock with this pulley. The pulley was installed a year ago though. Could the belts still be the problem? Would the clutch in the AC compressor require the entire compressor being replaced?
What was the part number on the belt your using
They are Gates belts, numbers K-060408 and K-040292. There was a write up under drive pulley installs and these were the belts that were recommended. Those are the ones that I have on now.
HerpDerp1919
09-29-2015 02:02 PM
