Help went through 2 mass air flow sensors and think its cuz of my injen CAI!!!
Old May 30, 2004 | 04:59 PM
99maxx-on19's's Avatar
I had my car about a year and never had a problem..not even a belt sweak!!But then i bought a CAI...A few months later.I say 5 months my car started jerking on the freeway and i pulled over and then it stopped.the next day my car whouldn't stay on at all. it kept dying and boging out!So i took to a mechanic and he changed the MAFS and it stoped and never had a problem...till about 2 weeks ago when it started doing the same thing,so i went and got another sensor and the problem stopped again..but yeasterday i got the same thing happening.the car starts pulling and dyes out.So i unplugged the sensor and replugged it and it stops!What can i do because the sensor is making me sooo mad!!Do they sell another sensor that will work better if not where can i get a cheaper one because i don't wanna buy another one.Also is this even my problem?is it something else?Someone please help me with this!!
Old May 30, 2004 | 05:06 PM
happyricefob's Avatar
V^___^V
did you reset your ECU?
Old May 30, 2004 | 05:16 PM
no you mean un plug the battery or what??
Old May 30, 2004 | 05:20 PM
V^___^V
1. Turn the selector screw clockwise to its stop.
2. Wait 2 seconds.
3. Return back by turning the screw counterclockwise to its stop.
4. IMMEDIATELY REPEAT steps 1 to 3.
Old May 30, 2004 | 05:23 PM
ok how will i know i did this right?Becausee my CEL is on because i did the speen limited removal.Or does this not matter?
Old May 30, 2004 | 05:28 PM
NYC_Maxima97's Avatar
I've had an Injen CAI for about a year now and never had a problem. My guess is there's something else causing it, just my own .02
Old May 30, 2004 | 05:36 PM
yeah i was thinking maybe it was because of rain or something!I just hate this sensor!!!!
Old May 30, 2004 | 05:50 PM
Maximum96's Avatar
before replacing, clean the sensor with alcohol and q tip. The oil from the filter causes it to mess up.
Old May 30, 2004 | 05:52 PM
your talking about the lil peice in the middle right?
Old May 30, 2004 | 05:54 PM
2. Wait 2 seconds.
do i turn the key and try this??
Old May 30, 2004 | 06:05 PM
Maxin It's Avatar
Turn your car to "ON" just before starting so you see the Check engine light. Then use a tiny screwdriver (to turn the little plastic white screw inside) and follow those steps. Then the check engine light should start flashing. Count the short and long flashes to determine the code. There can be multiple codes so keep counting.
PS: If you have never done this, the screw is protected by a plastic film. It should be behind the plastic film covering it.
Old May 30, 2004 | 06:17 PM
Maximum96's Avatar
Yes the 2 little sensors in the middle of the MAF, I just sprayed TB cleaner on mine. If it is completely messed up, u might find good deals on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old May 30, 2004 | 06:21 PM
Maximum96's Avatar
I have been through 2MAFS also, now when i clean my filter i oil very very little and clean my MAF regularly, and no problems now, knock on wood.
Old May 30, 2004 | 06:29 PM
You mean you sprayed throttle body cleaner on the sensor?
Old May 30, 2004 | 07:11 PM
enjetek's Avatar
just make sure you dont put too much oil on the filter or let it run off when you dry it because it can cause the mafs to go bad. maximum96 is correct. good luck and just make sure it is dry.
-myke
Old May 30, 2004 | 09:33 PM
meanbean's Avatar
I dont think spraying throttle body cleaner on the MAF is wise. It's very sensitive and you will probably end up messing it up. If you have to clean it, take a Q-tip with alochol and gently wipe off the dust. You can also clean off the MAF screen/filter as well while you have it apart. I'm running the Injen CAI myself and have had no problems. Just make sure you follow the recommendations stated and do not over oil the filter when you end up cleaning it. That issue has been known to cause the MAF to RIP.
Old May 30, 2004 | 10:20 PM
Y2KSESteve's Avatar
I've owned 3 maximas with Injens and no MAF sensor problems here.
Old May 30, 2004 | 10:50 PM
S15 SR20DET's Avatar
ur intake filter prob sucked water or oil to the MAF bc me friend had the same prob happend to his altima and his MAf went bad and the reason was bc the filter had too much oil on it and it sucked it all to the MAF
Old May 31, 2004 | 12:02 AM
liqidvenom's Avatar
brotherhood of tq
maybe all that n2o your spraying is messing it up?
Old May 31, 2004 | 07:01 AM
Maybe.....but i tryied to clean it with a q-tip and that seemed to help as well as when i tried to reset my ecu.No more jercking.So thanks fellas!
Old May 31, 2004 | 07:51 AM
RyCrisp's Avatar
I had a similar problem happen to me...where the car started boggin then would die when I'd come to a stop like it couldn't idle. It was one of my hoses came disconnected from my intake. Reconnected and was just fine. Maybe something like this happened and you left it disconnected and something flew through the maf?? Not sure.
Smackasmith
Feb 1, 2016 12:40 AM
RWCreative
Sep 21, 2015 11:01 AM
conansriver
Sep 11, 2015 10:26 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
