starter ?
Old May 31, 2004 | 02:18 PM
bang4thebuck's Avatar
starter ?
I have a '95 SE 5spd . I turn the key and get nothing. It appears the battery is charged. I can compression start the car.
What should I check ? If the starter goes bad, will it do nothing ?
Thanks for your help. B4B
Old Jun 1, 2004 | 01:27 AM
bump... Is there other things I should check before assuming its the starter ? Thanks
Old Jun 1, 2004 | 07:29 AM
NmexMAX's Avatar
dot dot dot ...
Slam the starter with a sledgehammer and it should work (not kidding) but this is a sign that it's on its way out (starter) This happenend to me.
Old Jun 1, 2004 | 10:41 AM
MaximaEvolution's Avatar
if it just makes a "click" sound, it's time for a new starter. Listen for the "Click"
Old Jun 1, 2004 | 10:55 AM
thekenone's Avatar
could be the ignition switch. pull off the little connector to the starter and run a lilttle piece of wire from the positive lead on the starter to the place where you pulled off the wire. if it starts then its the ignition switch if its does nothing its your starter or its not getting power.
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
