Anyway to make the Steering Wheel tighter and more responsive?..
My Camry's steering felt better than this Maxima. I know it's not a BMW, and Maxima's are suppose to have a easy steering wheel. But it's way too loose. Is there anyway to make it a little tighter?..
First things first to check the alignment (ie toe and camber). To firm up the steering, I'd suggest getting new urethane endlink and swaybar bushings (~$20) and possibly replace the steering rack bushings. One of these days hopefully someone will make urethane steering rack bushings, but until then it's OEM replacements. I don't know how involved the install is though, but I'd figure after 100K miles or 5+ years use the steering rack bushing have softened up quite a bit.
Even with all this work, the Maxima steering will feel light. That's been a complaint of mine too. Light steering isn't bad because the car is responsive, but the on-center feel is just too loose to feel ideal.
Dave
Dave
All 4th gens cames with power-assist. Which means the steering gets stiffer as you go faster. As most of can tell, the steering does not get any stiffer at any speed. It stays just as soft at 5mph as it does at 50mph. That means the power-assist has failed. To my knowledge, power-assist is built into the R&P which means we have to replace the R&P to get back the stiff steering we once had.
HEY, I think I found how to fix our problem
http://forums.skylinesdownunder.co.n...c/20275-1.html
I would rather have the power-assist stuck in "High-speed mode" than in Low-speed mode.
Dave
Around town and on the freeway, the redesigned suspension provides the kind of comfort most buyers want, and equals the best in its class in terms of silence and smoothness. From the driver's point of view, the Maxima is maneuverable and has light variable-assist power steering that takes the effort out of parking and lane changing.
Dave B is 100% correct, while we do have power-assist, we do NOT have variable-assist. There is a distinct difference in that power indicates that we have power steering constantly, however our steering is NOT variable meaning it does not get tighter with speed. The loose steering feeling remains constant through the speed range (causing instability problems at high speeds). Again there is no known fix for this yet, except removing power steering.
-Cyrus
-Cyrus
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
