Air Bag Light Flashing. Need Help.
Old May 31, 2004 | 08:51 PM
chan168's Avatar
I have a 99 Nissan Maxima SE with dual front airbags and dual side airbags. One day all of a sudden, my air bag light started flashing. I tried the reset procedure (pressing the button on my the driver's side door 5x within 7 seconds), but it didn't work.
Any other suggestion?
How much would it cost to repair?
Any good and affordable mechanics out there?
Thank you.
Old May 31, 2004 | 09:25 PM
Nick7455's Avatar
-Open door
-turn key to On
-Press switch as many times as u can for 10 secs
-turn key halfway between LOCK and ACC (this is not labeled but is considered #1 position)
-close door
-start engine
Keep at this until it works......remember turn the key to #1 (not labeled on ignition switch) after button presses.....go try and let me know what happens
Old Jun 1, 2004 | 04:42 PM
chan168's Avatar
Nick7455,
You are the MAN! Thanks a lot. You've saved me a lot of money. After my third attempt, the light went off.
Greatly Appreciated,
Chan168
Old Jun 1, 2004 | 06:00 PM
Nick7455's Avatar
Trust me the FAQ is not the way to do it. I thought that I couldn't get mine off for almost 2 months and almost bought a new side airbag...then i tired it like 3 times and just did different key position...then it went away!!!
2 months later and still no light =P
Old Jun 1, 2004 | 06:09 PM
95snakekiller's Avatar
What Button!!!!!!!!!?????????
Old Jun 1, 2004 | 11:33 PM
Nick7455's Avatar
calm down...it is on the frame of the car.....look at the area where the end of the door closes onto. These is a little rubber button there....that is what needs to be pressed ^ ^
Old Jun 2, 2004 | 07:14 PM
oh the sensor switch for the interior dome lights??
Old Jun 2, 2004 | 11:15 PM
Nick7455's Avatar
correct....it is called the drivers door switch...dds
Old Jun 3, 2004 | 01:24 PM
well, i fully appreciate your help, that blinking light was driving me absolutely nuts for the past 3-4 months...
took 3 trys and the 1st time all it did was slow the blinking down lol but it worked!!!!
YOUR THE MAN!
Old Jun 6, 2004 | 06:48 PM
chan168's Avatar
Nick7445, guess what? After 1 week of no airbag light blinking, it came back today. Been busy, but I will try the reset again when I have time. Would suck if I have to keep doing it every week. Might have to take it to the dealership and pay an arm and a leg.
Old Jun 6, 2004 | 08:27 PM
oldngivout's Avatar
Willing to learn
I have found that disconnecting and reconnecting the airbag harness at each possible place will sometimes turn off the light.
The 98-99 are especially prone to this because of the connection in the seatback for the side airbag. Don't forget to try this one, although the ones under the seat may do the trick.
Old Jun 6, 2004 | 08:45 PM
Nick7455's Avatar
I did mine and it has never came back on......if i comes on again u have to get it fixed....
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
