Maxima has too much power. thats not a good thing in some cases.
Old Jun 4, 2004 | 08:08 AM
  #41
TooMAX's Avatar
Originally Posted by mzmtg
I do all the work on my car so I know it's done right.
Exactly. And on the rare occasion I need to take it somewhere, they never seem to disappoint me. Like when my CV boots were replaced, they torqued the lug nuts to about 200 ft-lbs.
As far as oil changes, I never used to jack it up, but now I do. Not that it helps with access (stock springs), but jacking up the front driver's side corner using the tow hook lets about a half pint or so more of the old oil to drain out.
Old Jun 4, 2004 | 09:06 AM
  #42
VIP Maxima
Originally Posted by 98SterlingMax
Also, ramps are absolutely the safest way to lift and hold a car up, it's impossible for it to fall off.
for ur name !
Old Jun 4, 2004 | 02:43 PM
  #43
98SterlingMax's Avatar
Humble '06 TL Owner
Originally Posted by 98SterlingMaxSE
for ur name !
Just a guess, I bet our cars kinda look the same too...
Old Jun 4, 2004 | 08:11 PM
  #44
Chopsuey0079's Avatar
sorry but in this scenario... its all your fault. ive never had troubles with this. The Maxima does not have too much power anyways, i wish i could get more at the wheels without breaking the bank. but basically... learn to drive.
Old Jun 4, 2004 | 09:05 PM
  #45
Eric425's Avatar
do u guys take the panel off to access the filter when doing it on the ground? the splash guard thing or w/e u call it....
See the little plastic pins on edges of the mud guard? Theres a few of them. You pop those off, and you can get the guard off. I've never done the ground oil change before, and it doesn't seem likely that I will, since the last time I took those pins out to change some belts, it was a hassle, and I don't think I'd be able to do it while reaching around the wheel too. I also don't think I'd be able to get under the car to reach the drain plug. Oh well, doing the ramps don't take too long, and it'd be easier for me.
maxinout93
Oct 27, 2015 01:29 PM
MikesChevelle
Aug 9, 2015 11:50 AM
Gsantos79
Aug 8, 2015 07:41 AM
MikesChevelle
Aug 6, 2015 11:36 AM
