ECU Question
Old Jun 4, 2004 | 03:17 PM
Cornbread's Avatar
ECU Question
Is "resetting the check engine light" in the STICKY the same as "resetting the ECU"? Thanks.
Old Jun 4, 2004 | 03:22 PM
98fiveSpeed's Avatar
what do u mean by "resetting the ECU" ? Theres no such thing.
Old Jun 4, 2004 | 03:23 PM
97SEMAXI's Avatar
yes it is the same, if i think i know what you mean
DAVE Sz's Avatar
Hooooooonda.....
Right!?! If you disconnect the battery overnight the ECU will reset, ut when you reset it after checking for codes it's basically the same thing.
Old Jun 4, 2004 | 03:38 PM
Cornbread's Avatar
Thanks guys for your responses. You know when people put YPIPES on they always say that they reset their ECU afterwords. Do they do it buy the battery method like Big D said or will resetting the check engine light work? That is all I wanted to know I guess. I am installing a YPIPE soon.
Old Jun 4, 2004 | 05:38 PM
DAVE Sz's Avatar
Hooooooonda.....
They are both the same thing. You either reset it using the reset CEL method or disconnecting the battery for at least 30 minutes.
Old Jun 4, 2004 | 05:50 PM
Kevlo911's Avatar
Kevlo for President
Disconnecting the battery doesn't reset the ECU/clear a CEL on a 4th gen from my expirences on about three 4th gens.
Old Jun 4, 2004 | 08:07 PM
joosdawg's Avatar
that is also my expirence with my 99 se, i threw a code and kept the battery disconnected overnight reconnected it in the morning with no avail, then i came to the org and thats when i found out what id been missing. So many people with so many answers, and theres my answer right on the top of the forums as a sticky i was like holy s***...anyway yall dont care bout my story so thats all
Old Jun 4, 2004 | 08:12 PM
DAVE Sz's Avatar
Hooooooonda.....
Disconnecting the battery resets the ECU, it does NOT clear the CEL.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
