AHh cant get my starter out!
Old Jun 6, 2004 | 12:03 PM
danman700's Avatar
Ok, so im doing the starter noise fix. ( http://www.motorvate.ca/mvp.php/516 )
i have everything out, well the whole intake setup, and battery and i think i've given myself enough room. But there are a bunch of hoses and lines like right there where a wrench would go, so i cant use a wrench, so i go with the socket wrench with an extention so i can get them out, wont budge...wd-40...still wrong budge, few taps with a hammer, still wont...i actually ended up messing up the end of the socket and the head of the bolt is getting pretty beat from hittin it with the hammer.. I need some imput on this one. Im thinking maybe i could move some of those hoses and lines that are keeping my trusty wrench outa the way? But i dont know exactly what they are. If you guys got any ideas help me out pleasee i need to fix this noise.
Old Jun 6, 2004 | 12:50 PM
THT's Avatar
THT
Throbbing member
PB Blaster or Liquid Wrench would be a better solvent than WD40. Sorry I can't offer any more info but good luck and hopefully someone else who's done this can help you out further.
~THT
Old Jun 6, 2004 | 01:11 PM
aznprid972's Avatar
use a breaker bar. thats what i did and got it out.
Old Jun 6, 2004 | 02:00 PM
njmaxseltd's Avatar
Use a 1/2 inch drive 6 point socket and a breaker bar.
Old Jun 6, 2004 | 02:49 PM
MDeezy's Avatar
yes a break bar is needed. It took me a while to get mine out (damn air tools),
I got mine out with a half inch on the bolt, plus a 6" break bar, and man did that still take some torque.
Old Jun 6, 2004 | 06:45 PM
sislen's Avatar
Removing Starter
I had the exact same problem. I had everything taken out of the engine compartment. I removed one of the starter bolts without a problem, but the second bolt would not come out... PERIOD...
I tried oil, WD-40.. etc..
I finally got a 1/2" SOCKET.. and a 3 ft breaker bar. I pulled so hard on that thing I thought I was going to break something and finally the bolt came loose. I almost fell on my a$$ when the bolt came loose.
Make sure you follow the required torque specs. when re-tightening the starter bolts. Each bolt has a different torque spec. I think the short bolt has a lower torque spec.
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
