Max does not want to start without applying gas pedal...
Old Jun 9, 2004 | 06:07 AM
MaxedOutOfCash's Avatar
Pizda Boy
Especially when cold... It used to start by just turning the key.... Now I have to put my foot on the gas pedal and press it in order for the car to start... Is that something with the starter? ? ? ?
Any help is appreciated...
Old Jun 9, 2004 | 06:24 AM
image's Avatar
Maybe try cleaning out your injectors alex??? I think there is something u can put in your gass tank... ::BumP::
Old Jun 9, 2004 | 06:28 AM
njmodi's Avatar
Do I get a tax break?
Try the following:
1. Clean out the throttle body
2. Clean out the IACV
3. Replace the ECTS - this provides a signal to the ECU during start up (about a cold/hot engine) and controls the fuel mixture during startup... (this part is about 30 bucks from either the dealer or Autozone etc.).
Old Jun 9, 2004 | 08:09 AM
98fiveSpeed's Avatar
do what njmodi said. But Im sure you'r problem will go away after step #1.
Old Jun 9, 2004 | 10:56 AM
Socrates's Avatar
I agree. Most likely the Throttle body needs cleaning. Should improve your mpg also.
Old Jun 9, 2004 | 10:58 AM
FLO_BOY's Avatar
with a rash of starter issues lately, it might just be it! my car was acting similarly before the starter died.
but, if I were you, I'd start on the easy and cheap fixes listed above first...
good luck,
FLO_BOY
Old Jun 9, 2004 | 01:32 PM
MaximamixaM's Avatar
also check all of the stickies-it looks like nissan feels it is normal to have to use the acclerator to start a cold engine.
Old Jun 9, 2004 | 01:47 PM
DAVE Sz's Avatar
Hooooooonda.....
Who's Alex? Try this. Turn the key to on, wait for the BEEPING to stop and turn on the car. Even if that works get a new fuel filter, pour some techron or seafoam in the tank, might as well put some ATf into the spark plug holes.
Old Jun 9, 2004 | 01:55 PM
Jeff92se's Avatar
I'm needing a caw
How does it run when warm? Okay?? If so then it's something to do with the engine's cold start program.
Do what the guy said above. It's what I would recommend.
The TB has a little airbypass hole to allow air around the TB plate when it's closed. If that's blocked, that might also prevent the engine from starting when you have the foot off the gas pedal. So if you clean the TB, make sure to spray a bunch of fluid into this little hole. I'd probably take off the TB to clean it at this point
Old Jun 10, 2004 | 03:34 AM
Pizda Boy
thanks for the replies... the TB has been cleaned... I will try the fuel filter....
Tha'-Max
Aug 30, 2015 01:14 AM
305head
Aug 26, 2015 09:03 PM
seesole
Aug 26, 2015 11:22 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Jcof88
Aug 3, 2015 10:43 PM
