LED Taillight?
LED Taillight?
Hey all,
Does anyone know where i can get the LED strip too put into my tail light? and also is there a write-up on how to do it. I some ORG member have them, and i really like to do it too.
V
V
You can buy most of the parts you need at RadioShack... there is no how-to available yet. It is a simple concept (electrically) - but I imagine it requires some thought/design to make it work properly and within the restrictions of the existing harness/wiring.
If you read the post you will get an idea of whats involved.
http://hidforum.com/forum/showthread...&threadid=3266
http://maxima.cardomain.com/memberpage/202250/8
Originally Posted by kevlo911
Look at hte Altima how to in OUR 4th Gen FAQ's
Where did you get your LED from, could you tell me what size to get, i saw the page where there is one that like 5" X 3.5 or something like that. Please let me know exact what you used. O and buy the way, you an Indian?
Vinay
Originally Posted by 98SterlingMaxSE
wat else do we need?
prefboard (what size?)
LED's with resistors from cwithk
wires?
wires?
(6x8) I think is the size, when you go there you will know which one will fit, if you can't tell just by looking at them than you don't need to be doing this.
Use any kind of wires. One for brake, one for clearence(when headlights are on), and one for ground.
This is not hard people, it is simple, but VERY TIME COMSUMING. I am selling LED tails, in fact I have one set done but I am trying to find the taillight harness so it will be plug and play for whoever buys it.
I will prob put them on ebay since I have a few people who want them, so they can bid agaisnt eachother. I will let everyone know when they are for sale and if the harness will be included or not(still easy to do, but people will have to cut and splice the stock harness)
Give us a write up and maybe pic's showing the back of the prefboard with the led's wired up. Also, could you please post a Original cutout (traced on paper) of the prefboard, so that we can print it out and cutout it out and work on it, i mean get it ready, before we have to take the light's out, because it may take some of use longer to soilder and LED's and wire it up.
VP
VP
Here ya go....nice and neat....it's getting old having zillions of people ask the same questions, so I might as well post some pictures....enjoy
Test fitting the plexiglass....
Plexiglass painted silver...
LEDs wired in parallel with resistors...
Completed boards mounted in tails...
Finished product...
Front clearance lights...
The same thing was done for the turn signals and reverse lights....the front turns boards were made the same but mounted differently. The front clearance lights I mounted the LEDs directly into holes drilled into the housing. I don't have pics of the front turns.
-Tony
Finished product...
-Tony
Funny thing, I ordered LEDs from CWITHK to do all the interior lighting. I got the resistors and used them but as soon as I plugged that in nothing worked. Removed the resistors from the circuit and everything works fine, almost 6 months now.
tony, my man ! PLEASE do a write up, PLEASE !
now that u have stopped modding and as you said " i have lots of free time now", it woudlnt hurt to help out a few fellow org members who really wanna do this mod. I BEG YOU !!
TONY
TONY
TONY
TONY
where did you get that board and did u drill it urself?
TONY
TONY
TONY
TONY where did you get that board and did u drill it urself?
Originally Posted by d_warner
Hey Kev. I'm gonna redo mine. Think I'm gonna try a dual resistance on them this time. So that they are dim as tails, but bright as hell on the brakes. Whatcha think?
Sounds great, Let me know when you are done.
araffio, the back of my board looks exactly like yours. I hot glued everythink down too.
Yes, Tony's way of mounting LEDs adn resistors is much cleaner. If I ever do LED lights again, I will take that route. Actually I gonna make clearence lights into LED turning signals next weekend, so lets see what comes out...
BTW, whoever does LED project on 95-96 taillights, beware of that light reflector, cause it blocks LEDs. Picture in my sig is old. I opened tails again and moved boards to the sides. Or you can put LEDs in a way that they are right between reflector strips, up to you..
TONY
TONY
TONY
TONY
TONY
TONY
TONY
Sorry, it's just not happening....
Yes, I cut and drilled the plexi. I used Microsoft Excel to lay out the holes, thats why they're perfectly straight.
-Tony
I got how to wire the LED's, but i don't remember how to wire them up so that when you apple the brakes they will burn brighter. Could anyone explain how to wire them so they are not bright at regular drive lights and bright when applying brakes.
VP
VP
The 95/96 reflector is in the way so I might not put the LEDs behind it and leave it like that since it's not going to show anyways. I'm planning on using 5k mcd LEDs for the dim part and maybe 7k mcd LEDs for the brake part. Going to research the dim/bright thing later and I'll try to do that instead.
Kev,
I think i got everything i need to know, but one other thing, Do you have a pattern of the 97 gxe tail prefboard so that i can work on the LED lights without having to take my light apart for now. it may take me awhile to do cuz of time, so i don't want to be without taillights. If you have one plz email them too me. PEROVPP@HOTMAIL.COM.
You don't want something that's too low or else it won't be bright enough during the day.
