Manual Tranny Issues '96 SE
Old Jun 17, 2004 | 01:13 PM
Phaeton's Avatar
My Max started making some screeching metal-on-metal scraping/grinding sound the other day shifting through all the gears. I took it to the dealership the other day, had them take the tranny apart and they found that the input shaft bearing was actually broken! I initially thought it was the throw-out bearing that needed to set in (the sound started after I had the clutch replaced).
Has this ever happened to anyone or should I take it to another dealership for a second opinion?
Old Jun 17, 2004 | 01:43 PM
NmexMAX's Avatar
dot dot dot ...
Take it to a trusted mechanic, because the dealership doesnt use lubricant. . . . .
Old Jun 17, 2004 | 02:45 PM
97WhtSE's Avatar
I can bet money on it. Its the diferencial or shaft bearings for sure. Just have them changed before ur axles start poping out and oil starts to leak.
Old Jun 17, 2004 | 03:04 PM
Phaeton's Avatar
Spoke to the dealership again, and yeah they showed me the remains of my input shaft bearing. The rest of the bearing was floating around in the tranny making "spoon-in-a-blender" sounds and also caused a couple of seals to tear in the tranny, soaking my new clutch. They inspected all the gears for any damage and said everything else looked good.
So, another new clutch, a new input-shaft bearing, a couple of new seals, and about 13 hours of labor (most of it was dismantling and inspecting the tranny parts), will end up costing about $1500.
MAXSE5SPD
Sep 17, 2022 04:00 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
