15.9 @ the Trax, What the???
Old 06-18-2004 | 07:52 AM
Ninos_Maxima's Avatar
be the change u want2C
I have a 99 AT maxima as you all know,
Mods Warpspeed YPipe
CAI
Full Cat Back
2.5" High Flow Cat
I lowered tire pressure in the front to 25 psi
I took out the passenger seat, and all the matting and the trunk was almost completley stripped
I was at Great Lakes Drag way the other day, and my car ran 15.9 both times
r/t-5.9...
60'-2.404
330-6.771
1/8-10.309 @ mph70.38
1000-13.329
1/4 15.919 @ 86.80mph
It feels like my car is hesitating after 65mph, I got a diganostic twice, nothing came up, just got a oil chnage and a trany flush 'n fill, any body got a clue as to why I ran 15.9
Old 06-18-2004 | 08:22 AM
Kevlo911's Avatar
Kevlo for President
I ran a 15.9 at my first time at het track. I also had a 2.4 60', that is because I hesitated at the launch. I only have intake and all I took out was the spare tire and I had over a half of tank of gas.
You should be running 14.9.
How are you shifting? Are you leaving it in D? When was the last tiem you gave it a tune-up?
Old 06-18-2004 | 08:27 AM
waveridr85's Avatar
tranny could be loosing its grip, happened to me
Old 06-18-2004 | 09:33 AM
Brudaddy's Avatar
2.4 60'....that is why you are running 15.9 in 1/4 mile.
I mean, you need that down a lot lower to get into the 14's.
My 60' times the last time I ran were anywhere from 2.307-2.433 and that yielded an average 1/4 mile time of 15.2422 @ 92.454 (AVG).
I know from talking to most people, that 60' time is a huge factor. I am 5spd, however, and I don't know what would give you better 60' times. It sounds like you are doing all the right things.....tires, mods, etc.
It sounds like it might be bogging a little off the line. Maybe you ought to try to let it chirp a little, but not too much. I don't know, but your trap speeds are really low.
Old 06-18-2004 | 09:46 AM
1FSTMAX's Avatar
Damn... you need to learn how to launch yor car...
Old 06-18-2004 | 10:00 AM
VQvroom's Avatar
I havent gotten a legit time from the track yet, i have a stock AT 99 se. Ive beaten cars that run in the low to mid 15's. Something is wrong with ur car or you need to learn how to launch like 1FSTMAX said.
Better luck next time.
Old 06-18-2004 | 01:06 PM
JSutter's Avatar
I'm nutty for Nissans
I had a 96 auto with an intake ran 15.77@87.1. My 60' was 2.343, and 1/8 was 10.16@71.63. Its not your driving, its your car. How much wheel spin do you have? If none then you need a tune up real bad.
Old 06-18-2004 | 02:59 PM
Tune up, I just got a oil chnage, i got platinum plugs 6k miles ago, tranny flush n fill was done last week, How should I give it a tune up, i dont get it?
Old 06-18-2004 | 03:40 PM
What do you mean launch, its auto, all you do is Break tourqe right?
And how would I know if my Clutch is slipping or not?
Old 06-18-2004 | 03:45 PM
DAVE Sz's Avatar
Hooooooonda.....
Did you try at all without brake TQing? I wouldn't do it just because it ****s up the tranny and makes more wheel spin. You also ran only twice so that might have something to do with it. But I doubt it'll be any faster cause your car is already stripped and you should be running much faster.
Old 06-18-2004 | 03:46 PM
|Bijan|'s Avatar
UCF Lexus
wrong forum much?
Old 06-18-2004 | 03:52 PM
JSutter's Avatar
Check all the sensors: O2, knock, mass air flow, ect. Change the pcv valve, fuel filter.....im sure there is more.
Old 06-18-2004 | 03:56 PM
Fuel filter was changed like 6k ago, i checked the maf like 4 days ago when I installed my CAI, sholdnt it throw off a code if theres a sensor problem? I got a diagnostic to see if it was the ks but it said all clear twice, Iono whats wrong but its ****ing me off!
Old 06-18-2004 | 04:11 PM
Stupid Nissan and there Gay Auto Trannys, There so weak, WTF is my damn tranny slipping, I never Neutral Drop or anything, I only break torqued it like 5 times and the first two where at the traqs that day
Old 06-18-2004 | 09:12 PM
desertmaxima's Avatar
Did you check your tranny fluid level and when was the last time you changed filter and fluid.
Also are you going with OD off or on. I have a 96 auto but never ran it off the bottle. So I wouldnt know what times id get. But yea tranny does kinda slip every know and then. They arent really made to rag with really sluggish. My problem now a days is my top end isnt there cause it is an auto. Oh well swap coming soon. Good luck
Old 06-18-2004 | 09:19 PM
ABK's Avatar
ABK
What platinum plug are you exactly using? I hope not bosch.
Old 06-18-2004 | 10:38 PM
Max_PR's Avatar
It's probably your Knock Sensor. The CEL won't necessarily turn on when the knock is bad, to verify if it is good you should follow the check instructions in the haynes Maxima Manual OR let the Nissan Dealer run a Full diagnostic, thay should be able to pull-off the KS code if it has gone bad.
This is what happened to my Max. No CEL but the diagnostic at the dealer threw the code off and after replacement I could feel the difference.
I have almost those same mods and I'm also 96 auto and I ran a 15.6@89mph
hope the info helps
Old 06-20-2004 | 06:52 AM
I have NGK Laser Cut Plats, Im going to the trx again on teusday so I'll see, My freind Is gonna let me have his ks im gonna replace it and see. I asked my freind thats about to graduate from LTI he said it could be my TCC(Torque Converter Clutch) Sliping
Old 06-20-2004 | 08:12 AM
95stillenmax's Avatar
that dosent sound right to me
Old 06-20-2004 | 01:05 PM
arlan's Avatar
Switch to a Honda V10!
Old 06-20-2004 | 01:49 PM
DAVE Sz's Avatar
Hooooooonda.....
People need to stop with the O/D ON or OFF ****. He never gets into 4th gear at the track so having that on or off makes no damn difference.
Old 06-20-2004 | 02:10 PM
Honda Sux 123456
Old 06-20-2004 | 02:27 PM
Nealoc187's Avatar
SLOW
1) GLD is the worst track in the country, that's most of your problem right there.
2) Your 60' times were pretty bad. That's probably partly a result of being at that POS track you went to, and partly a result of inexperience.
3) I don't know what the weather was on the day you went, but you really can't compare times run at a crappy track in the middle of summer to those run at a good track in the cool weather of spring or fall, so don't try to compare them or you will just end up frustrating yourself.
I bet if you were to go run at byron or rt-66 in like 70 degree, low humidity, high pressure weather you would come back with like a 15.4-15.5 @ 89-90mph, which is right along the lines of where you should be I'd say.
Don't waste your time or money at GLD that track is just a waste of energy.
Old 06-21-2004 | 10:30 AM
Brudaddy's Avatar
wise words from someone who has raced a lot.
Take them to heart.
Old 06-21-2004 | 10:37 AM
LudeAEM's Avatar
Thank you Nealoc! Was it humid that day? Because i have a 96 auto SE that ran 15.8@87 on a HUMID day. I mean so humid i could see all the water vapor in the air. I have a CAI and y pipe. But with just and intake i ran 15.6@87 at IRP.
Old 06-22-2004 | 06:28 AM
These were the Traq Conditions, It was About 75-80 Degrees, Hmm it was a little humid the first time, Then the second run was around 8:30 so it was real cool up there and the humidity went down, it was around 65-70 deg, O and misquitos are freking huge up there!!!
Old 06-24-2004 | 05:06 PM
laylow1988's Avatar
are you driving backwards?
DoGGy
Tires and Wheels
06-02-2006 05:30 AM
MardiGrasMax
12-02-2004 11:08 AM
MaxDriver98
12-28-2001 12:34 AM
Quick Reply: 15.9 @ the Trax, What the???
