02 motor in 4th gen possible or impossible
Originally Posted by Midknight MAXX
No, Ni_Nos_Maxima is talking about swaaping the internals, ie. pistons/rods. Unixsvr-4 is talking about a complete motor swap.
Originally Posted by VQvroom
I think the point is........the 2k2 is a 3.0 so why swap? Why swap a 3.0 with a 3.0?
What the guy was saying was get a 2k3 or higher which is a 3.5, if your going to swap.
2k2 and up is 3.5.
Originally Posted by slammed95
Nope, it uses drive by wire. There's a potentiometer by the accelerator pedal, and the TB has a stepper motor on it to open and close. However, there isn't a 1:1 proportion between the pedal and TB. The ECU controls the TB differently under varying conditions. And when you let off the throttle, the TB plate actually closes slowly to reduce emissions, it doesn't slam shut like cable operated TB's. And when you start getting close to redline, the ECU starts closing the throttle to reduce power and make you shift without hitting cutoff.
comapre to 190. I will be happy with additional 65hp. and the difference between 2K2/3.0 and 2K3/3.5 is what 10hp ???
Originally Posted by unixsvr4
I agree that 2K2 is also 3.0, but then how the hell they are generating 255hp
Do a little research, you are on a Maxima website it should'nt be that hard. 2002 and 2003 Maximas have the 3.5 liter engine. The 2000-2001 use the 3.0.
That's what I thought that 2K2 and up is 3.5.
Finkle
09-27-2015 09:53 PM
