Plz Someone Tell me...?
Old Jun 19, 2004 | 04:19 AM
thekenone's Avatar
How to take off my spolier. i have a 95 se. and i see 4 bolts but when i went to loosen them the just spun around. any info would help.
Old Jun 19, 2004 | 02:28 PM
thekenone's Avatar
anyone taken theirs off?
Old Jun 19, 2004 | 04:18 PM
95stillenmax's Avatar
you gotta wait more than 2 hours for a response
Old Jun 20, 2004 | 10:22 AM
thekenone's Avatar
i did it was 10 hrs. between
Old Jun 20, 2004 | 04:38 PM
nazmax's Avatar
im not really sure how to take the spoiler off, but im really intrested
in buying the spoiler once you get it off, you can email me at naz6126@yahoo.com if you wanna sell it.
Old Jun 20, 2004 | 04:47 PM
my bad the times are messed up on here....did you check the how 2's
Old Jun 20, 2004 | 04:55 PM
MDeezy's Avatar
To take off the spoiler there are 4 bolts holding it in. Just pop your trunk, and take off that carpet things that is there ( there are a lot of grey things holding it up, you could just use a flat head screw driver and pop them out ), then just look at where your spoiler is connected to the trunk, and you just have to losen and take off the 2 bolts on each side. At the very end of the spoiler once you get the bolts out, just gotta give it a little bump with the fist to nock the spoiler out of this plastic grove this is also holding the spoiler down.
Forgive me if my explanation sounds a bit confusing, once you get that carpet off and take a look it should be all down hill from there, if your still having trouble I'll take some photots tommorow after work.
Peace.
Old Jun 20, 2004 | 05:47 PM
thekenone's Avatar
well i tried that and when i started turning the ratchet the screws turned also. was wondering if i needed to do something else
Old May 25, 2008 | 10:00 AM
paulreagan's Avatar
I'm in the middle of replacing my 2000 Maxima's rear brake rotors and pads. How do you disconnect the emergency brake? I cannot get the caliper to release the rotor unless the emergency is disconnected (?).
Old May 25, 2008 | 10:23 AM
QNO_A32's Avatar
use the search you ignorant POS
Old May 25, 2008 | 11:11 AM
darklegend06's Avatar
your also under the wrong section.
Go to the 5th gen section or search.
Old May 25, 2008 | 11:12 AM
fat_kid's Avatar
not even the right car...
Old May 25, 2008 | 04:39 PM
Snypa's Avatar
stop hijacking, create a thread of your own....wait.......Did you even search.? Its free you know.!!
KaxMaxSEAE
23
Jul 27, 2001 12:33 PM
madmax97
Mar 28, 2001 08:57 PM
tunedup
Mar 9, 2001 08:00 AM
tunedup
Oct 25, 2000 07:31 PM
