Goin from 15' sawblades to 17' SE rims: Do i need to lower?
hey i got a simple question. I am currently working a deal to get new 2001 AE rims, i currently have 15' sawblades. I drive a 1997 GLE, will i need to lower my car or will it look good with stock springs. I really do not want the 4 X 4 look. And if anyone has a pic with a 4th gen on 17 inch SE's WITHOUT lowering, can you please post a pic. Your help is greatly appreciated.
Thanks,
Eddie
Thanks,
Eddie
itll look 4x4, i have 2 maxes, one is lowered iwth 15's, and the other has 16's but is 4x4, the 15's looks a hundred times better lowered, check my cardomainpage, the pebble beige has 16's unlowered and the black max has 15's dropped
here is a pic of my truck. drag the link to the address bar to view it. the gap is hideous. i went from 15 to 17 too.
http://pics.bbzzdd.com/users/blk_g20/DSC00730_2.JPG
if i lower it, do i have to replace the springs and struts at the same time? the springs are must less expensive than the struts from what i see around. can i replace the struts at a later date or will the stock ones blow from the different springs?
well since you will be doing it yourself, i don't think you mean install shop... so im guessing you mean a website...
http://maxmods.dyndns.org/index.php?MaximaHandling
this will give you a price, and different opinions on what setup to go for... hope it helps
WHoa...........yer slammed Max with sawblades look very nice. Did you have to get a camber kit to maintain alignment geometries?
My wheels are 16x7, with 205/50/16 and yes I have the 4x4 look (check my webpage). I'm opting for adjustables.
True.........but with 15" rims, I figured that the drop has to be at least 2" or more. That might actually necessitate camber bolts to correct the alignment. I'm hoping that 1.5" of drop would be enough for mine since I didn't want to throw off alignment drastically with an extreme drop.
Originally Posted by s3roush628
Lowering is definitely the way to go, no matter what rims you have on your maxima. 2DaMax, when I lowered my 96 with 1.5 in H&Rs, I needed a new alignment but camber bolts werent necessary.
Originally Posted by 97maxsuperblack
OK i now know it is a MUST to lower after seeing darrick's pics. I am still new at this, how much will it cost to lower my maxima and where is the place to go.
1. How low do you want it?
2. How stiff do you want it?
3. How much to do you want to pay?, etc...
MaxLvr21
10-17-2015 12:11 PM
DC_Juggernaut
09-28-2015 04:07 PM
