Alarm Integrated with Horn
Old Jun 21, 2004 | 11:42 AM
A32Matt's Avatar
How can i hook up my horn to my factory alarm to make it beep when i arm the system like on the 5th gens? if this is somewhat easy i would like to attempt this cause during the day i can't tell if my system is armed without looking at the turn signals to see if they flash. i seen the mod to make your alarm beep in the how to's, but i want to hook it straight to the horn.
Old Jun 21, 2004 | 03:56 PM
PoePoe2797's Avatar
Yes you could do that....just find the alarm circuit, and find out which wires activate the lights (just lock/unlock a few times, probing each wire). Then you will need a bit of wire and an automotive relay. Run the light coming from the blinker tap to the trigger pin on a relay, and wire the relay in with the horn and there you go...
kmitchel
Oct 28, 2015 09:46 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
TONY92MAX
Sep 29, 2003 03:20 PM
kafene
Sep 7, 2000 02:28 PM
