SE Guys look at your engine bays
Old Jun 21, 2004 | 08:47 PM
matty's Avatar
Pass side where the ps lines come off of the power steering resevior and go towards the front of the car to a fluids cooler, I need to know the order of those hoses. ??
there is one going to the bottom of the resevior and one back to the ps pump...there are two lines going to the cooler thats located at the front of the car..please look and tell me which line goes where
Old Jun 22, 2004 | 04:37 AM
SkoorbMax's Avatar
I'm at work, but if you still have no answer for this by later tonight you can email me at ma_brooks@hotmail.com and I'll take a pic of my 97 and that should help you.
Old Jun 22, 2004 | 04:53 AM
DAVE Sz's Avatar
Hooooooonda.....
The one on the left goes to the cooler and the one on the right goes back to the reservoir. I THINK!
Old Jun 22, 2004 | 05:08 AM
96maxdaddy's Avatar
sorry to whor your thread, but I NEED the two little lines that connect the hard lines, so they can wrap around the radiator.
Anybody have part numbers for those?
If not I am going to the stealership today any way, so maybe I can help you out by looking at a schematic or something.
Old Jun 22, 2004 | 06:38 AM
matty's Avatar
I need to know right now ?? ? what lines go where ??
-matt
Old Jun 22, 2004 | 06:43 AM
optimus310's Avatar
I'm at work right now so I can't really tell, but does this help?
http://gallery.azmaximas.org/view_ph...ar&id=DSCN0421
Old Jun 22, 2004 | 07:31 AM
matty's Avatar
No you cant see what lines go to what side of the cooler...
-matt
Old Jun 22, 2004 | 09:42 AM
matty's Avatar
It will take someone 2 min to open your hood and look...
there are two lines, top and bottom, going to the front oil cooler for the power steering...one goes to the pump and one to the resevior...WHAT ONE GOES WHERE
please take a look
-matt
Old Jun 22, 2004 | 10:35 AM
bhmax's Avatar
On my 98 SE, the "cooler" is a piece of rubber hose making a loop in front of the radiator. Therefore, it would make sense that, at least on my car, you couldn't mess anything up by reversing the flow. Is there a cooler on your 96 that could make a difference?
Old Jun 22, 2004 | 10:51 AM
matty's Avatar
Yea really dont think it would make a difference either but one line goes back to the ps pump and one goes to the resevior....both go to a different place...just look for me
BTW: the cooler in front of my car is metal
-matt
Old Jun 22, 2004 | 10:53 AM
maximus_96's Avatar
i would appreciate it if you can tell me the part number and price after you find out. i need to replace one of the hose too, the one closest to the engine.
thank you
Old Jun 22, 2004 | 11:01 AM
matty's Avatar
Just replace it with from High Pressure PS hose at $2 a foot..I did both of them to move them out of the way for the SuperCharger
Anyone Know what order there in ??
-matt
Old Jun 22, 2004 | 11:15 AM
Stephen Max's Avatar
-matt
It absolutely does not matter. Hook it up one way and the fluid flows clockwise through the loop, hook it up the other way the fluid flows CCW through the loop. It works either way.
Old Jun 22, 2004 | 11:17 AM
matty's Avatar
ok..thats what i figured...thank you
-matt
Old Jun 22, 2004 | 11:19 AM
Bobo's Avatar
Are you referring to the 2 black hoses that come out of the bottom of the power steering reservoir. The 2 hoses are the same diameter. They feed out of the reservoir and don't cross over. The one on the left stays on the left and the one on the right stays on the right. You obviously know what they were disconnected from. So hook the one on the left up to the leftmost opening and the one on the right to the rightmost opening. Does that make sense? I looked under my hood and can't quite see where they feed into as there isn't enough light, but it shouldn't be rocket science!
Old Jun 22, 2004 | 11:21 AM
Bobo's Avatar
And if that fails, phone the stealership? Or go look at a service manual at your local parts store. Public libraries also have them, at least where I live.
Old Jun 28, 2004 | 07:45 PM
96maxdaddy's Avatar
Well I finally did it. I first went to the stealership ,and they wanted like thirty bucks for each of those hoses that connect the hard lines off the resivour, to the cooler line as it wrap around the radiadtor.
So naturally I was like F**K that, so I head to the local aouto parts store, and he said they had them. He pulls out this little box, and inside is a foot long piece of 3/8 power stering hose. It came out to like six bucks.
Any way I just got done replacing those hoses, and if any of you have to do it good luck. I am still bleeding where my knuckes hit the bumper, and there is very little room. But I did it and thats my story on that one.
Old Jun 28, 2004 | 08:20 PM
matty's Avatar
You need about 8 feet of hose to make those connections ??
yea the area is really tight in there, my knuckles were bleeding from hittin the radiator so much
-matt
Old Jun 28, 2004 | 08:46 PM
maximus_96's Avatar
i've got some leftover hose from my transmission oil cooler. its rated up to 400 PSI. can i use that as a replacement? below is a picture of mine just to make sure i'm talking about the right hose. the one one the right is leaking a bit as you can see its darker on top and bottom. please drag the link to your address bar to view the picture.
http://pics.bbzzdd.com/users/blk_g20/DSC00704.JPG
Old Jun 28, 2004 | 08:49 PM
maximus_96's Avatar
also, can you lift out the reservoir? the top clamp seems awful to get to. i assume i have to empty out the reservoir first. should i refill with synthetic ATF? or plain old steering fluid.
Old Jun 29, 2004 | 06:51 PM
96maxdaddy's Avatar
I used plain dexron three, by valvoline. It was the right stuff ,and it was what was available. As for synthetic, I dont know, but I would use whats recomended to avoid problems.
Old Jun 29, 2004 | 08:26 PM
maximus_96's Avatar
so can i safely use the 400psi transmission cooler hose to replace the short hose on the resevoir
Old Jun 29, 2004 | 09:32 PM
Oblongshapes's Avatar
i have those hoses i ordered them from nissan, but it wasnt the problem.... they were like 50 dollars, ill sell em to you for cheap
Old Jun 30, 2004 | 05:59 PM
96maxdaddy's Avatar
Posted by blk_g20 - Yesterday at 10:26 PM
I say go for it if they are the right size. There shouldnt be a problem with the fluid eating the rubber cause they are safe for atf. And those are not high pressure lines anyway so I say you should be good to go.
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
Nintensity
Aug 13, 2015 05:41 PM
