98-99 194 LED's wher do you get them
Old Jun 26, 2004 | 12:54 PM
superblack98se's Avatar
Where do you guys buy your 194 LED's to change the color of the speedometer from?
Old Jun 26, 2004 | 12:56 PM
aznprid972's Avatar
i thought the 98-99 models uses #74 bulbs.
try: http://www.superbrightleds.com/cgi-b...gi?product=CAR
im planning on ordering some bulbs from them soon
Old Jun 26, 2004 | 03:20 PM
DAVE Sz's Avatar
Hooooooonda.....
98-99 don't use either 194 or 74. The bulbs are proprietary bulbs. 74s will work however and you can get them here http://www.superlumination.com/ .
Old Jun 27, 2004 | 04:53 AM
blkhawk500's Avatar
I thought I read somewhere that 194's will work also, with a little dremelling though. is tht true?
Old Jun 27, 2004 | 06:28 AM
Blackwind's Avatar
74 will work however its not nearly as bright as stock.
Old Jun 27, 2004 | 06:32 AM
That is correct, that is what I am going to do since the light output is a lot more.
Old Jun 27, 2004 | 06:37 AM
Blackwind's Avatar
could you send me a write up after your finshed?
Old Jun 27, 2004 | 06:47 AM
all you do is take the cluster out(look in the how to's sticky), then just use the dremel and make the openings wider until the bulbs fit in... that simple
Old Jun 27, 2004 | 06:49 AM
Blackwind's Avatar
will dermmeling the hole affect the metal connectors?
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
