My exhaust sounds like RICE!
Old Jun 29, 2004 | 07:49 AM
meccanoble's Avatar
Sports Button FTW
Just a little dissapointed at the high end sound of my exhaust. At idle i love it, u cant really even hear it. at low revs its great cause i can still hear the whistle from the S/C but at high end it just crackle's up and sh*t and gives small backfire at times. I have a 2 week old warpspeed y-pipe, budget resonated b-pipe and dynomax turbo muffler. It was professionally installed, so i doubt there are any air leaks but i'm just disappointed in the sound. My obx sounded great even at high end but this setup kind of embarrasses me. I took a video clip. I'll share wit u guys later on.
Old Jun 29, 2004 | 07:51 AM
2k3TitaniumSe's Avatar
Use a Powertech 1012 muffler. That should be good enough.
Old Jun 29, 2004 | 08:47 AM
Brudaddy's Avatar
Why did you change if you liked the sound of your other setup?
Old Jun 29, 2004 | 08:54 AM
meccanoble's Avatar
Sports Button FTW
cause i'm boosted and 2.25 exhaust is trash when your at 9+ psi
Old Jun 29, 2004 | 08:59 AM
DAVE Sz's Avatar
Hooooooonda.....
So is 2.5". At 9psi you're hurting your performance for not having a 3" setup.
Old Jun 29, 2004 | 09:16 AM
happyricefob's Avatar
V^___^V
mecca you should have went greddy SP2...
Old Jun 29, 2004 | 11:01 AM
Ninos_Maxima's Avatar
be the change u want2C
Yeah man even at 2.5 the pressure is still to high, you have to get 3- 3.5 if possible, The noise sounds real raspy right,
Old Jun 29, 2004 | 11:19 AM
belosic's Avatar
I added a 24" glass-packed resonator to my system, and the difference is like night & day. Get the biggest resonator you can fit in there. Also, having a muffler with a slightly smaller core than the tubing will help too, without hurting performance (ex- 2.5" tubing, 2.25" muffler core). I use a "meanstreak" muffler, it has a semi-straight through design (oval) with louvered core elements. Sounds great, no rice at all... almost like a newer GT mustang.
belosic
Old Jun 29, 2004 | 11:28 AM
1FSTMAX's Avatar
glasspack louvered resonators are crap, and rob power.
Old Jun 29, 2004 | 11:58 AM
Brudaddy's Avatar
True.....You got a point.
Old Jun 29, 2004 | 12:28 PM
nismos14's Avatar
§è~® f®ÈÄk
what did u do with ur obx? gimme gimme gimme
Old Jun 29, 2004 | 12:47 PM
nismology's Avatar
If I'm not mistaken you have a test pipe. That's not helping at all...
Old Jun 29, 2004 | 01:03 PM
Dave B's Avatar
Not DAVEB the parts guy
You'll never get a good exhaust sound when using an aftermarket muffler and y-pipe. All aftermarket mufflers are pretty loud and somewhat farty and raspy, especially above 4000rpms. The VQ just doesn't have a pleasant sounding firing order. If it were me, I would have done 2.5" exhaust with a Magnaflow resonator to a 5th gen muffler. Shortly before the muffler I would install a dump pipe for track use.
Old Jun 29, 2004 | 01:06 PM
Jeff92se's Avatar
I'm needing a caw
Hey Dave. A couple of guys have said they opened up their 2k muffler's opening to 2.5". Do you think that will improve the muffler's flow performance?
Old Jun 29, 2004 | 01:17 PM
erty67's Avatar
Decal Specialist
Having the same OBX setup, I know how nice it sounded. Sorry to hear the new setup is not as nice. At least the car is faster! ...could you still use the OBX muffler? I think RI-max has a GReddy SP1 muffler for sale too. just a thought.
Old Jun 29, 2004 | 02:16 PM
michaelnyden's Avatar
or you can always do an exhaust cut-out that is switchable like hlh did in the end.....then you can run your 2.5" and not bother selling it and buying a 3" and your exhaust will stay relatively quiet, then when you want ultimate power, you can hit the switch and bam the cut-out opens up and then you have a god knows how large exhaust system effectively....that would be for pure power...
Old Jun 29, 2004 | 02:23 PM
1FSTMAX's Avatar
mecca you should have gone with the RSR muffler..
Old Jun 29, 2004 | 02:25 PM
1FSTMAX's Avatar
I believed they opened the inlet to 2.5", but the internal diameter of the muffler is 2.25".
Old Jun 29, 2004 | 04:01 PM
fishpony's Avatar
great i just ordered a warpspeed y and i have a dunomax muffler is mine going to sound like crap or is it just cuz he's boosted?
Old Jun 29, 2004 | 04:22 PM
Jeff92se's Avatar
I'm needing a caw
That's the thing. I believe the max muffler is not a straight through type. If it were, then I could understand your reasoning. But I think the Nissan ones are a chambered type. So inside there is not 2.25" or 2.5" piping. The flow just enters the muffler though an opening and then goes back and forth until it reaches the twin outlets. So that's why I wonder if opening up the inlet would do anything. I could be wrong though.
Here is a muffler test:
http://www.autospeed.com/cms/article.html?&A=0382&P=3
I "think" Nissan mufflers are like this (but with the varible thingie)
Hmm maybe you are right. I dunno.
Originally Posted by 1FSTMAX
I believed they oped the inlet to 2.5", but the internal diamater of the muffler is 2.25".
Old Jun 29, 2004 | 04:30 PM
Jeff92se's Avatar
I'm needing a caw
Nissan muffler: So it does't really look like opening up the inlet would help
Video: http://66.218.71.225/search/cache?p=...yc=48546&icp=1
Old Jun 29, 2004 | 05:43 PM
Ceasars Chariot's Avatar
Old Maxima Legend
my ws ypipe setup also sounded like trash ! i enjoyed the performance side but hated the way the car sounded. im glad those days are over.
it just stinks that these vq's sound nasty , kinda like a fine rear on a woman cutting some nasty farts, just dont add up ! lol
Old Jun 29, 2004 | 08:23 PM
fishpony's Avatar
anybody else have a dynomax muffler with warpspeed y-pipe? sound allright or like trash?
Old Jun 29, 2004 | 08:33 PM
tweeter007's Avatar
I had a ws y pipe with a dynomax s-turbo set up and it sounded the same way, crackly,raspy,ricey and crappy, until a removed the resonator that was there and added a 18" Dynomax Thrush for use as a resonator. All the rasp and rice went away, minimal drone,now sounds deep but mellow and very aggresive 3000 rpms and up. It is actually just the sound I was looking for. I have no complaints.
Old Jun 29, 2004 | 08:38 PM
Keyser Skoze's Avatar
How would the Flowmaster, Catman headers, and a turbo sound? Good for preformance or robs it?
Old Jun 29, 2004 | 08:48 PM
fishpony's Avatar
is the thrush a glasspack, how much was it? also i heard this will kill performance is that true?
Old Jun 29, 2004 | 09:01 PM
BlueC's Avatar
wat
Its all about the stock exhaust manifolds. Ever wonder why 350zs have such nice sounding exhaust? They are RWD, the exhaust manifolds are basically equal. FWD the engine is sideways, so one header will be longer than the other. Thats why cattman headers make everything sound 100x better, cause they are equal length. Its next on MY mod list....
Old Jun 29, 2004 | 09:25 PM
fishpony's Avatar
man im kinda ****ed i put my dynomax muffler on now, and a month before i order my y-pipe, guess i shoulda thought about that. oh well ill see how it sounds.
Old Jun 29, 2004 | 11:01 PM
liqidvenom's Avatar
brotherhood of tq
yea mecca i say you save some cash and get the caman headers and that should help out the sound.
Old Jun 29, 2004 | 11:15 PM
meccanoble's Avatar
Sports Button FTW
i wish i could spend 700 dollars to get a nice sounding exhaust . I went custom cause i couldnt afford the greddy.
I have warpspeed y-pipe, budget resonated b-pipe (magnaflow resonator) warpspeed straight pipe, dynomax turbo muffler. I'm wondering if i'm getting exhaust leak but who knows...dam i really want headers but i'll have to save a real long time....stupid installation.
btw i have a video, just need someone to host
And its not that bad its just not as good as the obx i had. At idle it sounds amazing, nice and quiet and hummy but at high rpm's, like if u just shift up it gets nasty.
Old Jun 30, 2004 | 03:04 AM
maxima19671's Avatar
I have a custom 3in exhaust all the way back. With a cherry boom resonator, and apexi N1 box. The apexi box sounded like s-it, so I changed to the HKS N1 type box and it cut the noise by half. Used to be able to hear my car from about two blocks away. Now it more like half a block at high rpm. ( Oh yea, mine is a 99 se turbo
Old Jun 30, 2004 | 04:14 AM
DAVE Sz's Avatar
Hooooooonda.....
I don't really believe that since the N1 is an obnoxiously loud muffler. The thing is so small so it's no surprise, looks really cheap too.
Old Jun 30, 2004 | 06:56 AM
tweeter007's Avatar
Your mixing it up with the cherry bomb, which is a louvered/****ty glasspack that will hurt performance a bit. The Thrush is higher quality It does not hurt performance really at all. It's internals look basicaly like a resonator. They are fairly cheap I paid $30 CAD, about $22 USD.
Old Jun 30, 2004 | 07:17 AM
Dstyle's Avatar
meccanoble- Does "warpspeed straight pipe" mean that you have your cat removed? if so, before you spend money on a new exhaust set up you should try putting the cat back on and see how it sounds. it could make a lot of differience. a friend of mine with a turbo eclips put his cat back on and a lot of the rice sound went a way and he was much happier with it, plus the car smelled really bad without the cat. just a thought. or you should do what dave b says with the gen 5 muffler. his car is really quiet, but then agian he doesnt have boost.
Old Jun 30, 2004 | 08:26 AM
fishpony's Avatar
thanks tweeter i guess when i get my y on i'll look in to gettin a thrush instead of stock resonator, i might have to get a custom made b pipe cus i just found out yesterday that i have a huge dent in mine, just my luck
Old Jun 30, 2004 | 08:40 AM
meccanoble's Avatar
Sports Button FTW
nah this is it, in fact after i dyno tune i'm not spending anymore money on this car. This car has effected me financially, school wise, and just in what i put in to myself. Its taken up a lot of my time and my friends have told me this since day one. Now family is letting me know. I'm content at where its at now even though i want more. The last thing i bought was a tip which should be coming in today. The exhaust isnt horrible just not what i expected. I wanted my car to sound like a subaru STI but its still fine.
If anyone can host the video for me i wo uld be grateful.
Old Jun 30, 2004 | 10:44 AM
Powerman5115's Avatar
How big is the video? I can host about a 7.5MB video if its that small. Email it to me at JMooney5115@yahoo.com
Old Jun 30, 2004 | 03:54 PM
CaLSoNiC
My exhaust sounds like **** now too, after I put my Y-Pipe on. I was at Cattman meet in Tuscon and at least 10 people told me it was cuz of Warpspeeds ****ty flex section. The idle is awesome sounds like a V-8, but once I go above 3K its all rice. Sucks a nut, but I like the extra kick in the pants and my stereo helps with the bees.
Old Jun 30, 2004 | 04:16 PM
fishpony's Avatar
anybody else have a warpspeed y and hate the sound? i know tons of ppl got them through the gd jus lookin for opinions
Old Jun 30, 2004 | 04:24 PM
mine sounds just fine....there was a period there where my exhaust sounded horrible.....but that was when I had my stock muffler on and my y pipe was brand new and my stock cat was going...now that it sounds great except for this one time that I had an exhaust leak, but that was midas' fault...
