45xxx miles. What should i get done?
Old Jul 2, 2004 | 03:50 PM
99MAXSE-L's Avatar
Recently i hit around 45,000 miles in my 99 se-limited. Is there anything that i should replace? I havent done anything major since i bought the car, except oil changes, obviously. What should i do and how do i do it?
Old Jul 2, 2004 | 05:36 PM
Bobo's Avatar
You should have had it serviced at 30,000 miles.
What condition is the air cleaner in?
Fuel filter long overdue for replacement.
Radiator long overdue for flushin and coolant replacement.
etc, etc.
Old Jul 2, 2004 | 06:17 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
might be a good idea to do the following
- BG Fuel Induction service (costly but well worth it)
- BG Engine Flush (also costly but worth it)
- Cooling System Flush (as rmurdoch mentioned)
- Tranny Flush (depending on what tranny you have, auto or manual)
- Tire Rotation/Balance (has this been done before?)
- Brake Inspection (sometimes included in tire rotations)
Based on your mileage, looks like you have another 15K to go before doing a tune-up at 60K
Only other advice I can give you since your max is a '99 is to watch out for the ignition coils, that is a common problem on '99s
? - are you the original owner of your Max or did you buy it used?
Old Jul 2, 2004 | 06:54 PM
Bobo's Avatar
The difficulty I am having with this thread is "After almost 1,000 posts, why is this thread even being initiated"? I am relatively new to the Board, am not mechanically inclined, but I can reason and absorb information and go from there.
Old Jul 2, 2004 | 08:20 PM
99MAXSE-L's Avatar
yeah i bought the car brand new. U think i should wait and get all that done at 60k?
Old Jul 3, 2004 | 06:31 AM
there is a 60K service that the dealer recommends that bundles most of those services, + tune up, oil change and an inspection, kinda costly, but some of the stuff you can do yourself which could save you quite a bit of $$, depending on your mechanical skills, but its up to you
Old Jul 3, 2004 | 10:11 AM
SamMan23's Avatar
I'd check the air filter and check the color, feel and smell of the atf and leave the rest of it alone till 60k. Most people spend way too much money on things that don't make a difference on their cars.
Old Jul 3, 2004 | 10:33 AM
Kevlo911's Avatar
Kevlo for President
Man you prob lost compression by now. That is way to many miles.
Old Jul 3, 2004 | 12:44 PM
Bobo's Avatar
Take the car to a radiator shop and get them to check the pH of the radiator coolant. They do this with a strip of paper. Before I got my Maxima I never paid any attention to flushing rads, and consequently have had to replace a few. It is sound preventative maintenance to flush the rad and replace the antifreeze. It pays dividends down the road. The antifreeze breaks down after 2 years or so.
Old Jul 3, 2004 | 01:09 PM
Bobo's Avatar
Also, I take it your car is stock. I replaced my air filter twice by 44,000 miles as it was filthy. The manual recommends replacing it every 30,000 miles, but I doubt anybody waits that long, except maybe you. If you have never replaced yours, your gas mileage will have reflected that. If you are not into getting a CAI or Popcharger and plan on keeping your car for awhile, you should seriously consider getting a K&N panel air filter. You will notice an improvement in performance and fuel economy as it breathes better than OEM and lasts forever, with periodic cleaning and maintenance you can do yourself.
Old Jul 4, 2004 | 07:40 PM
on rmurdoch's post regarding the K&N panel filter and the maintenance suggestions
last thing you'll want on your hands is a skittish Max b/c of neglected maintenance
Old Jul 4, 2004 | 08:41 PM
TAPOUT's Avatar
You will lose
I thought you were supposed to put nitrous on your Maxima at 45,000 miles!!!
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
markevans999
Oct 25, 2015 08:27 AM
maxima-junky
Oct 7, 2015 06:13 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
