Error code 0301 - replace ECM. Is this critical?
My husband says since the car runs fine I can ignore the error and not replace the ECM. I think it should be replaced.
Can anyone advise the correct course of action?
Please help this girl who loves her 95 SE!
No it's not. PXXXX are different from DTC read by turning the screw on the ECU.
Like I told you earlier, I would replace the ECU, do you know anyone with a 95-96 maxima or I30? If so, swap out hte ECU for a few hours and see if you get hte code on their ECU or if you car runs better with thier ECU.
Originally Posted by 2DaMax
Where is Phelan? I'm in So-Cal with a 95 SE, 5 speed though. I'm pretty sure it doesn't matter.
As I understand it, the ECU must be for an AT.
Hmmm.......I gotta find out from Nismo if that is so. He had an automatic and converted to manual. He didn't mention about changing ECU too but his is a 97-99 GXE. Come to think of it, I think he got a 95 ECU since they are better than the others.
Originally Posted by mwolfe
Phelan is in the high desert - near Victorville.
From my understanding, you can use an AT ecu in a Manual but not vise versa. I guess you could in this situation because it is only a test. ou will prob get other codes but that is ok.
mrc00l88
Jan 25, 2024 01:14 PM
doobadoo
Aug 15, 2015 06:43 PM
