How hard is it to change a fog and a corner/parking lamp?
Old Jul 6, 2004 | 09:32 AM
PhaZe's Avatar
I finally bought the drivers side fog lamp and I just ordered a corner lamp from carpartswholesale.com. I couldn't find any write ups for it so I was wondering how hard it is and what kind of tools I need.
Old Jul 6, 2004 | 09:45 AM
Bluebird's Avatar
I am Roid Rage
Sell your max.
You'll need a screwdriver for the corner light and a 10 or 12 millimeter socket for the fogs.
Old Jul 6, 2004 | 09:46 AM
FutureProof's Avatar
Haven't tried the fogs yet, but the clearance lights are a piece of p*ss... Just need a philips, a flathead, and a rag...
Unscrew the clearance light (philips screw just above the headlights), wrap the business end of the flathead driver with the rag, wedge it between the headlight & the clearance, and just wiggle the bastard out, takes about 2 minutes...
The owner's manual should show you how if you're unsure, or check this:
http://forums.maxima.org/showthread....34750#poststop
Cheers
K
Old Jul 6, 2004 | 09:53 AM
PhaZe's Avatar
Originally Posted by Bluebird
Sell your max.
lol thanks, I only ask because I've never been mechanically inclined. I don't like to go in poking around and end up screwing something up. I understand my questions are pretty noobie but you'd be surprised how clean my max is
Old Jul 6, 2004 | 11:25 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
heres your drivers side turn signal/sidemarker
the = is the front turn signal and the + is the side marker.
put your keys or flat head screw driver with a rag on the untensil, and put it in between the = and the + and push out with the tip of the utensil facing the drivers side. then unscrew the phillips head. and your done.
as for fogs. make sure you have all the hardware.
2 fog lamps. 2 mounting brackets and i think there are 8 bolts. 2 bolts on the left side and on 1 bolt on the right side. and then one bolt secures the fog lamp to the bracket. visa versa with passenger side.
Old Jul 6, 2004 | 11:48 AM
PhaZe's Avatar
Thanks killcrap but I think you're talking about the bumper lights. Im changing this light when it arrives
as for the fog lights, Im replacing the drivers side when I can. I guess it aint too hard
Old Jul 6, 2004 | 11:50 AM
PhaZe's Avatar
I don't want to clutter up the forums with another thread so Im going to ask here, is there a discount code for JRnissan? I want to order the floor mats and some maintenance parts like the fule filter and drain plug and spark plugs and crap like that
Old Jul 6, 2004 | 12:02 PM
killcrap's Avatar
its "maxima"
Old Jul 6, 2004 | 12:03 PM
killcrap's Avatar
oh yea and sorry. use a lot of wd40 on the socket of the clearance lamps. it will pop right out.
doctorpullit
Jul 20, 2019 09:31 PM
03VQMAX
Nov 10, 2015 03:39 PM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
