Spark Plugs- Which are the best?
Old Jul 6, 2004 | 02:06 PM
Mark97SE's Avatar
Just wondering what everyone has to say about plug selection.
I was thinking about the NGK Platinum or Iridium, and I am looking for opinions on these or any other plug.
Old Jul 6, 2004 | 02:15 PM
NmexMAX's Avatar
dot dot dot ...
NGK Coppers
Old Jul 6, 2004 | 02:21 PM
mansurxk's Avatar
ngk coppers
Old Jul 6, 2004 | 02:23 PM
tpduke112's Avatar
bosch platinum 4
Old Jul 6, 2004 | 02:47 PM
(_8*(l)Homer's Avatar
NGK Coppers. Get them at Napa or something. They are BKR5E-11 for like 1.19 each
NmexMAX's Avatar
dot dot dot ...
Originally Posted by tpduke112
bosch platinum 4
Old Jul 6, 2004 | 02:54 PM
tpduke112's Avatar
LOL, Whats wrong with bosch platinum 4's?
Old Jul 6, 2004 | 03:06 PM
Terran's Avatar
They've been reported to make the car run like crap...may even have caused serious damage, not sure. Stick with the NGK, coppers are cheaper, plats will last longer.
Old Jul 6, 2004 | 05:52 PM
maxima_1995's Avatar
what about iridium NGK? i spent $$$ for these
Old Jul 6, 2004 | 06:50 PM
Keyser Skoze's Avatar
Bosch 4's are great for american and expecially german cars but not ours. They make you guzzle gas and they do make the car run like crap. I installed them on my old Max and then removed them a week later.
Old Jul 6, 2004 | 07:15 PM
Wmaxima's Avatar
Nology (Silverstone) spark plugs are the best
www.Nology.com
Old Jul 6, 2004 | 07:16 PM
tpduke112's Avatar
Really?!? that's exactly what there not supposed to do?
Old Jul 7, 2004 | 01:58 AM
{-_-}'s Avatar
stick with the ngks... if those don't work, i suppose denso would... but coppers will be the best bang for buck.
remember the anti seize and electrical pastes.
Old Jul 7, 2004 | 07:20 AM
someone2's Avatar
just for clarification, coppers are not only cheaper, but will give you generally better performance as well. copper is a high conductance (low impedance) material. it conducts electricity well (only gold and silver conduct better), which is why it is used for most wires (also cheap). this means that it will give you a better spark (better performance, gas mileage, smoothness, etc) than platinum, and be much cheaper.
the only problem with copper is that it will eventually corrode after being exposed to air. this is why it must be replaced relatively often. platinum on the other hand, is very resistant to corrosion and has been known to last up to 100,000 miles and more. the drawback is that your spark will be just a little bit weaker, which robs a little performance (you might not even notice). also platinum costs quite a bit more (but the price is close to equal when you consider how much longer they last).
as far as iridium plugs, they're relatively new and somewhat trendy. my guess is that they're all hype and combine some of the different characteristics of copper and platinum. i have not used them myself so you'll have to do your own research to be sure.
in the end most people agree go with a good brand name copper for the better performance and save a couple bucks, just make sure to change them according to the intervals recommended by the manufacturer. don't forget to check your wires too.
Old Jul 7, 2004 | 07:42 AM
Brudaddy's Avatar
+1.
Very well said....
Old Jul 7, 2004 | 07:56 AM
NmexMAX's Avatar
dot dot dot ...
Well said for a newbie, only the last part, we have direct ignition, no wires, so he probably meant check your coils. . .
Old Jul 7, 2004 | 09:32 AM
Nick7455's Avatar
I had bosch in there when i first got the car....was told by midas they were NGK but after 2 of my coils went out I took it back there to find out they put in bosch......I wouldn't go as far as to say there is less performance or gas mileage...after 6 months on NGK I have seen really no difference so I would just say DONT USE BOSCH cause it will mess up your coils.
PS that was back when I was young and naive (16 yrs).....now I do all that myself but one advantage is that midas paid for both coil packs and labor PLUS new ngk copper plugs and since I have a 99 I would have to say I made out pretty good for their mix up
Old Jul 7, 2004 | 10:17 AM
sagemistse's Avatar
I had bosch platinums in my max when i brought it. but i changed to iridium plugs about a year ago. I have to say i did feel a little better preformance. but now I am about to change to copper to compare.
Old Jul 7, 2004 | 05:07 PM
loco max's Avatar
Can't go wrong with NGK
Old Jul 7, 2004 | 06:13 PM
tpduke112's Avatar
does it matter which bosch platinums, like are u guys talkin about platinum, platinum 2, or platinum 4?
Old Jul 7, 2004 | 06:34 PM
Prophecy1's Avatar
NGK PLATS OR NGK COPPERS ONLY!!
Forget about bosch man.. God...
Read the stickies btw.
Proph
Old Jul 8, 2004 | 06:22 AM
someone2's Avatar
haha my mistake. . . i actually don't have a max so i'm not familiar with all the details, but i'm getting there. i joined the forum mostly to help out my 16 yr old bro (bday was yesterday) who was lucky enough to acquire one. so i'm really just here to learn a few things, and spread a little general knowledge when i can.
Old Jul 8, 2004 | 08:59 AM
ogparjay's Avatar
are you serious damn.... i have the bosch plat 4, thanks for the info i'ma change it right now, nothing else to do.
Need help
23
Oct 2, 2015 08:56 AM
Gingerheadman
Oct 1, 2015 05:11 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
