CHECK ENGINE code
Old Jul 7, 2004 | 05:30 AM
zone1982's Avatar
CHECK ENGINE code
hey guys my check engine lite came on and i checked the codes it came out to be 0309 and 0705 i know 0705 is EVAP Control System but for 0309 it said undefined so i thought i did it wrong i went back and checked it again but still it came out to be 0309 any one have any idea what it can be?
and how do u fix the 0705 code
Old Jul 7, 2004 | 05:41 AM
Kevlo911's Avatar
Kevlo for President
0705
Diagnostic Trouble Code 0705 points to a problem with the Evaporative Emission Control System.
This malfunction is detected when the EVAP control system has a leak or the EVAP control system does not operate properly. (EVAP = EVAPorative emissions.)
Possible causes include...
- incorrect fuel tank vacuum relief valve
- incorrect fuel filler cap
- fuel filler cap vent remains open or fails to close
- foreign matter caught in fuel filler cap
- a leak in the line between the intake manifold and the
EVAP Canister Vacuum Control Valve
- foreign matter caught in the EVAP CVCV
- leaks in the EVAP canister or fuel tank
- leaks in the EVAP purge line (pipe and rubber tube)
- EVAP purge line rubber tube bent
- blocked or bent rubber tube to EVAP control system pressure sensor
- loose or disconnected rubber tube
- EVAP CVCV and circuit
- EVAP Canister Purge Volume Control Solenoid Valve and circuit
- absolute pressure sensor
- tank fuel temperature sensor
- MAP/BARO switch solenoid valve and circuit
- blocked or bent rubber tube to MAP/BARO switch solenoid valve
- O-ring of EVAP CVCV is missing or damaged
- water separator
- EVAP canister saturated with water
- EVAP control system pressure sensor
- refueling EVAP vapor cut valve
- ORVR system leaks
This is a "jackpot" DTC. It points to so many things you don't know what to check. It is often combined with another DTC which is more specific and therefore more helpful.
Old Jul 7, 2004 | 02:04 PM
nitromax's Avatar
just checked Haynes manual, 0309 is EVAP canister vent control valve is open--depending on year, emission model ( fed or cali ), it may or may not be controlled by vacuum or
Old Jul 7, 2004 | 02:06 PM
nitromax's Avatar
oops, that's "or pcm (ecu)"
Old Jul 7, 2004 | 03:52 PM
zone1982's Avatar
where do i find the evap canister vent control valve
Old Jul 7, 2004 | 06:05 PM
Maximized Jiggs's Avatar
Can anyone give info on the whole EVAP code and what to do.
Old Jul 7, 2004 | 06:23 PM
nitromax's Avatar
on '93, '94, & '95 fed emission models, a vacuum operated purge control vave is mounted on top of the canister. on '95 cali emission models and all '96 and later models, an electronic purge control valve, controlled by the pcm is used. location of second valve unlisted in text.
Old Jul 9, 2004 | 01:17 PM
M3EuroS52's Avatar
how about a scanner code 1447?
Old Jul 9, 2004 | 01:27 PM
Maximeltman's Avatar
ya, evap purgr flow monitor fault. also, a 0111.
I have a 0510, and a 0512, both tied into my downstream o2 sensor. is this anyway linked to my knock senser?
________
Volcano Vaporizers
CorollaULEV
30
Aug 9, 2021 08:11 PM
magneto112
Sep 10, 2015 12:52 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
